March 10, 2026, 12:12:55 AM *
Author Topic: circuit modulator with 4-250  (Read 4645 times)
mario_puzos
« on: May 15, 2011, 03:20:28 PM »
hi i need a modulator circuit with two valves or 6156 4-250 Huh
« Reply #1 on: May 15, 2011, 06:08:59 PM »
Mario,
  I am not sure what you mean. Do you mean modulate a 4-250 by a 6156? If so, this could mean the 6156 would be a screen modulator, or clamp tube modulator?
   Looking around I found a neat two tube circuit with a 4-400 modulated by a bias shift modulator using a single 304TL:
http://www.813am.qsl.br/artigos/moduladores/hileman/the_bias_shift_modulator_cq_apr_54.pdf
mario_puzos
« Reply #2 on: May 15, 2011, 06:58:55 PM »
hi jim I need a circuit that uses a modulator valve is to modulate 4-250 plated at a couple of 4-400
« Reply #3 on: May 15, 2011, 08:43:19 PM »
Mario, Look at the attached schematic. Maybe this is closer to what you are looking for?
Schematic from following source:
http://www.g8wrb.org/data/Eimac/Care-and-Feeding-of-Power-Tetrodes.pdf
mario_puzos
« Reply #4 on: May 15, 2011, 08:58:03 PM »
thanks jim .. it will analyze a hug
« Reply #5 on: May 16, 2011, 03:46:36 PM »
hmmmm
I'm getting the picture of a pair of 4-250's modulating a pair of 4-400's...........
I don't know if the 250's will make enough audio
