November 23, 2025, 10:08:27 AM *
Author Topic: 5BTV install  (Read 5704 times)
N8LGU
« on: April 04, 2011, 06:29:00 PM »
I put this up last Autumn after I had to cut down my 90' pine tree.
"Rock Cave Dave"
« Reply #1 on: April 04, 2011, 07:01:33 PM »
There is something very appealing about the simplicity of a nice clean vertical installation, at least to hams Smiley
Take care not to exceed the power rating of the 75 meter loading coil, as I recall even with the "high power" version you have to watch it on AM.  I bought one of these back in 1975 and it still gets used for portable setup once in awhile.
« Reply #2 on: April 04, 2011, 08:27:57 PM »
Let me tell you about my 5BTV experience. I worked an awful lot of AM and CW using that aerial. I liked to pound brass on 15M and made alot of DX contacts with it. I echo Rodger's sentiments about the 75/80M resonator. Mine had a tendancy to get water in it. I placed it in the oven for about 20 min. @ 180°F I then placed a bead of RTV around the top where the metal meets insulation.
N8LGU
« Reply #3 on: April 05, 2011, 09:48:00 AM »
    I was wondering about the AM capability of that 80S resonator. Hustler says 1000 W. I assume thats PEP. I only run 100 W carrier so it should handle it. I won't be running the big rig on it. I have two stingers cut. One is for 3705 kc and the other is cut for 3885 kc. I can tilt it down and change the stinger in less than 5 minutes. Performance has far exceeded my expectations on 80M.
"Rock Cave Dave"
« Reply #4 on: April 05, 2011, 06:20:16 PM »
I used mine with an Apache without any issues.
« Reply #5 on: April 13, 2011, 04:00:46 PM »
The Hustler has been around a long time and seems to be a favorite with DXexpeditions, for some reason.
Easy to "throw up in a hurry"Huh Magical properties ?
Looks like you using ground mounted radials.
