June 01, 2024, 05:49:23 AM *
Author Topic: Hallicrafters SR-42 Vibrator  (Read 2594 times)
W6TOM
« on: March 23, 2011, 12:56:16 PM »
  I have a Hallicrafters SR-42, 2 meter AM transceiver. It has an internal vibrator, 4 pin, 2 small pins and 2 large pins, it will run off of 12 volts. Does anyone know what type of vibrator this is and where I might find one?? Thanks!!
                                  W6TOM
« Reply #1 on: March 23, 2011, 01:43:05 PM »
The one in mine is marked Mallory Type G1501.
Antique Electronic (and others) sell solid state replacement units that will probably work OK.  Otherwise it will have to come from a hamfest or someone's junk box and vibrators aren't the most reliable component every produced.
It might be easier to just operate the SR-42  from 120 VAC and use something else mobile Smiley
WB2EMS
« Reply #2 on: March 23, 2011, 04:36:09 PM »
Or use a small mobile inverter to run the radio off 120 VAC.  Probably more efficient than the original vibrator supply too.
73 de Kevin, WB2EMS
WB6NVH
« Reply #3 on: March 23, 2011, 04:50:44 PM »
If the vibrator is still present, but doesn't start or run well, you can hook it in series with a regular 40-60 Watt lamp bulb and use your wall socket to clean the contacts up.
The cost of a solid state vibrator is about what an SR-42 is worth and they seem about as robust as a canary anyway.
Those 4-pin vibrators are very common and you ought to be able to source a good one for about $ 5.
But...who's running VHF AM mobile these days?   Shocked
Geoff Fors
Monterey, California
Page created in 0.031 seconds with 18 queries.
