Well...finally finished the linear and got it on the air this week. Got good reports. Very clean amp, no garbage out (except what the 706 puts in). This is for anyone who is interested in bulding one of these puppies...I'm sure it can be improved.
At the moment I have the amp set at 100W (carrier) out with 8W in. The only issue I had turned out to be the 706 (shocker eh?). It has pretty bad asymetrical modulation in the wrong direction and sends the drain current downward with voice (and thus the RF output). I have not looked at this yet in the 706 manual but more suspect the carrier balance. So in the meantime it is installed and working. It is one band only right now....80M.
Because this is not your usual linear...using switchmode fets at 3.8MHz never mind using as a linear
, there was some Xperimenting. Mostly for me it was the bifilar choke T2. I thought that 3 turns would do it (the calculator told me it was OK), but needed 10 turns on a 43 core to clean up any noise. I filtered and bypassed the hell out of all ins and outs. The case happened to be one I had on hand as well as the PC board which I etched from double sided stock. In fact all the components I had on hand except the DC on-off relay which came from Roger N1XP. I had all the cores and had some IRFP260N FETs (the same as the Class E modulator). Total cost was what I paid for the parts over time at festers (I know, priceless).
Not seen in the trunk photo on the other side of the amp case is the heatsink,fan and LP filter. The sink was a little small, so I added a PC fan (onto the sink where it belongs). I was particularly concerned with heat on these FETs. I cut some 3/8" thick solid copper as a heat spreader for each FET. The FETs mount directly to the copper and they are insulated from the sink using silpads (and lots of heat grease). I'll worry about overheating the FETs somewhat less on one of those hot summer days....
Sorry for the hand sketched (and erased) print. All I have time for right now. Well, first I have to thank Mark KA2QFX. When I heard that Bob K1KBW and Ken ???UDZ were making amps using this method, Mark kindly informed me what he believed was used and then sent over an LTSpice diagram of what he recommended so I could take it for a virtual spin. Over time I modified it to my liking; if you would like a copy email me. Mark and I conversed many times via email and he provided much advice. TNX Mark!
Circuit decription (for those that care): It is a 2 FET unit as you can see and draws about 10A at 100W carrier and 13.8V DC input. The in and out xformers are binocular types per Helge of Motorola fame. The output xformer I completely over-did with 6 cores
. But in my defence I did not really have a good handle on figuring out what the saturation points were for the cores. The conductors are enameled types and/or teflon.
I expected the bias setting to be touchy as the transconductance of these FETs is very high. I ended up setting the bias at about 1.5V. At 3.5V some instability began to occur....I was pretty surprised that the FETs did not begin to show idle current until about 3V. I initially set the bias at 3V to set the temp compensation. Then turned it back to 1.5V.
As mentioned I also added a simple thermal compensation circuit using a small xistor to keep the FETs from running away and getting hot about it. The xistor is mounted to one of the copper spreaders and provides neg temp. compensation.
A last minute change was to add series caps in the drain circuit. I used 715 series orange drops. They have some inductance but I was more concerned about RF current.
The cores are the FB-43-1020 as used in the E rig. I used these for T2 and T3. I used smaller cores for T1. T1 and T3 are binocular types as noted. T2 has a neg feedback winding to reduce the gain of the amp and add some stability.
I think the most work was all the control circuits and relays. Also the remote control head and the control cable. I decided that I wanted remote control, so I made a simple control head with a drain current meter and on-off switches for the fan and the linear. Also I added a low pass filter, a 5 pole unit on the outpoot so my PW little machine will not swamp out those nice 28 meter foreign broadcasters
. I think the 3rd harmonic was about 40 dB down as measured on my spectrum analyzer. Enough for a mobile.
I may get ambitious and build a 4 FET unit next year (like the BIG boys). We'll see how this one does (or doesn't). BTW I saw Bob's 4 FET unit and Ken's 8 FET (!!!) unit...beautiful stuff...mine is pretty ugly with single sided PCB construction.
The trunk photo shows the rats nest. The linear is under the 706...the device to the right is an audio amp as the 706 has PW speaker audio.
The antenna many have seen before. Mercedes enthusiasts look at it in horror.
Its a single band homebrew center coil type.
That's my story...the experiment will continue....
~ps
