the softrock works but i'm not sure if it works as it should. if i am rx'ing on 3.885 and a huge signal is on 3.880 i do not see a big carrier sitting there next to 3.885. i got it working and need to mess with it some and just havn't. if i dont do anything with the softrock in a few weeks i may look to pass it on. just have tosee.
ok well i'll check out the links. and do me some reading.
Brandon,
The SoftRock - maybe the crystal needs to be moved/changed to slide that image down the band. Does the sync detector and pan adapter work OK? Bud, what do you think?
It's well worthwhile to get it running right with the R-390 - for the sync detector, sharp filters and spectrum display. You will hear better. Don't give up on it yet.
