January 21, 2026, 04:29:03 AM *
Author Topic: Aitch-Tee 20 on the air  (Read 21545 times)
« Reply #25 on: February 02, 2011, 04:56:07 PM »
It's also a matter of making things more complicated than they need to be. Proper design would ensure that a human could torque down a single-slotted set screw (or set screws) with a flat blade screw driver and the shaft would turn without slipping.
The first step in the proper direction would be to use a fine thread on an adequately sized set screw.  6-40 or 8-40 maybe on larger knobs. A torx head would work great.  They don't self-destruct with excessive torque the way allens and bristos do. I have never busted one trying to turn it, but I did break a driver once.  The splines remained intact, but the shank at the end of the driver couldn't take the torque and literally shattered to bits.  When a screw is stuck, I have found PB Blaster to be a big help.  Works much better than WD-40 or Liquid Wrench, but stinks like hell.
Another thing that sucks about allens and bristos is that the driver blade is sometimes left with a permanent twist after you try to turn a stuck screw. I've had that to happen to both the short L-shaped drivers and good quality Xcelite drivers with a plastic handle.
« Reply #26 on: February 02, 2011, 09:17:21 PM »
With 2 set screws on that HT-20 Id suspect its time to measure the torque on the Cardwell (Im guessing but its Cardwell in the HT-90) cap.
And if you get tired of tightening drive it up here some Nearfest.
« Reply #27 on: February 03, 2011, 06:38:03 AM »
The tuning knob drives a gear assembly that turns the tuning dial, a roller inductor, and variable cap all in tandem.  I did lubricate the shaft bearings on everything the best I could and it's much better, but I have my fingers crossed that the setscrews will stay put this time.
W3DBB
« Reply #28 on: February 03, 2011, 09:08:16 AM »
Doug
beautiful downtown Strodes Mills, Pennsylvania
