May 19, 2024, 06:30:17 PM *
Author Topic: Gates choke ID?  (Read 2016 times)
KC9LKE
« on: December 29, 2010, 01:32:34 PM »
I’ve looked on the web for hours and can’t find any info, and BC-1, 250 prints are not helping much either. I was told that these came out of a 500T.
IIRC the specs are:
L1 is 15/5 H @ 500 mA 7000V,
L2 is 15/5 H @ 300 mA 5000V.
They sit on top of 1” ceramic insulators and both of them, L1 & L2 are mounted on a grey chassis. L1 is physically larger than L2.
There are three ceramic feed throughs on the chassis, #1 is connected to L1, #2 connected to L1 & L2, and #3 connected to L2.
In the BC-1 & BC-250, L2 is listed as the Mod reactor? It’s a swinging choke.
Information on how these chokes are connected in the plate supply or an interconnection diagram for a BC-500T would be a great help.
Thanks again!
Ted / KC9LKE
« Reply #1 on: December 29, 2010, 02:59:28 PM »
Are the two chokes round and potted????If so they sound like the swinger and smoother out of a BC 500....I scrapped out a junker Gates 500 and those chokes on the chassis now reside in my Tesla360..Definately not mod iron or reactors
    Each choke has an oil cap filter to ground......The B+for the Modulator comes off the swinger and the final B+ comes off the smoother Good luck....Steve
KC9LKE
« Reply #2 on: December 29, 2010, 04:55:26 PM »
Steve:
Exactly!
I saw the picture of your Tesla 360 a few weeks back and even printed it off, but forgot what post it came from.
Yes they are “cans” and potted, UTC. They are both 25/5 swinging chokes, not 15/5 as I stated. L1 is physically larger than L2..  I’ll add that L3 is the 50 HY Mod reactor.
Quote:
“Each choke has an oil cap filter to ground......The B+ for the Modulator comes off the swinger and the final B+ comes off the smoother Good luck....Steve”
Just to clarify then…
L1, the large swinger goes to a 8uF @ 3000Vcap, 100k bleeder, the modulators, and L2.
L2, the smaller swinger, (but called a smother because of its position in the circuit?),
and goes to a 2uF @ 3000V, and then on to the final. I say 2uF because it’s the only cap left that’s rated at 3000V except for the cap between the Mod transformer and the reactor.
I understand that You might have used different caps but am I on the right track?
Thanks!
Ted / KC9LKE.
« Reply #3 on: December 29, 2010, 07:44:04 PM »
I may have different chokes......I 'm gonna hafta look..I think I have a 5-25 hy(?)and a fixed 11 hy (?) I don't think two swingers will make much difference to your application ....I'd be interested in others comments..............  My Gates BC1=G 1kw rig uses a single swinging
choke and a single 8 uf filter........
