May 03, 2024, 05:49:34 AM *
Author Topic: NC-183D schematic please  (Read 3678 times)
AB3FL
« on: December 25, 2010, 09:26:21 PM »
I have just acquired an NC-183D in very good condition.  I downloaded the manuals from BAMA and they look OK.  Does anyone have a GOOD, CLEAN copy of the schematic not split into two pages or even two pages is OK if it is straight.  The BAMA one is skewed.
thanks
Tom - AB3FL
« Reply #1 on: December 25, 2010, 09:45:23 PM »
Check and see which version of the NC-183D you have.  One uses a 6J5 as the phase inverter while the other has a 6SN7 with one section used as the phase inverter and the other used as an amp in the S meter circuit.
Also make sure your receiver doesn't have the .1 cap from one of the rectifier plates to ground, it is a good transformer killer.  It isn't needed so just clip it out if it is in place.
AB3FL
« Reply #2 on: December 25, 2010, 09:59:38 PM »
Phase inverter is a 6SN7.  The schematic I have from BAMA shows the 6J5.
thanks
Tom - AB3FL
« Reply #3 on: December 25, 2010, 10:09:27 PM »
Mine is also the 6SN7 version.  Attached is a less than perfect electronic version but hopefully it helps.
* NC-183D schematic version B.pdf (1592.11 KB - downloaded 247 times.)
AB3FL
« Reply #4 on: December 25, 2010, 10:10:46 PM »
Thank You very much.  That will work
Tom - AB3FL
« Reply #5 on: December 25, 2010, 10:40:04 PM »
My NC-183D had more out-of-spec resistors than any other piece of gear I own.  Every 47K screen dropping resistor in the RF and IF sections was several times its marked and rated value.  I am suspicious mine was built with mis-marked components since they were all very consistently high and the original owner noted in the manual that he had rewired section 1-A of the bandswitch so that it ran at maximum gain on all bands to overcome low sensitivity problem.
Properly operating it is a good receiver.  It sounds great on AM and the calibration is good.  When I bought my NC-400 I assumed it would be a "super NC-183D" and it is in most ways but the NC-183D frequency stability is better on the higher bands.
Page created in 0.067 seconds with 18 queries.
