May 15, 2024, 04:02:52 PM *
Author Topic: 8 pin octal male plug where to get?  (Read 4078 times)
radionut
« on: December 16, 2010, 06:33:36 PM »
I am thinking of making a "plug in" rectifier and need a few 8 pin male octal plugs. Where would one aquire such an item if one wished to do so.
Thanks!
KD8MVH
« Reply #1 on: December 16, 2010, 06:49:31 PM »
Ebay.
N8UH
« Reply #2 on: December 16, 2010, 06:57:31 PM »
Antique Electronic Supply has some too. Or you could just bust out an old tube...
-Tim
radionut
« Reply #3 on: December 16, 2010, 07:49:07 PM »
Thank you!
N5KAT
« Reply #4 on: December 16, 2010, 08:28:26 PM »
I just bought 5 on ebay. Not even here yet.
Send address and I'll send you one
n5kat @arrl.net
« Reply #5 on: December 16, 2010, 11:43:53 PM »
Thanks!
KD8MVH
You can solder two diodes in a 8 pin plug.  But don't if the voltage is much above 300-400 volts DC.  If the voltage is higher you will need to use more diodes in series in each leg.  I use the 1N1508 IIRC, they are 1000PIV 3amp.  1000 volts peak is only about 600 volts RMS and it's never good to run them close to the max voltage rating.  I use 4 diodes in series in each leg even on a 600-700 volt DC supply.  The diodes are cheap enough to use more rather than too few.
