Bob,
The "best" mods for a DX100 can be very subjective. There is tons of DX100 & similar rigs advice on this board. Do a search. But my 2 cents is the following. Don't do all of the mods at once. It could be a real dog troubleshooting if "something goes awry".
Continue with the coupling caps, grid resistor, and defintely change the plate caps as well. Also do Tim's mod for 1625 bias with the zener on the driver transformer. That mod is a must to clean up lots of distortion when you lean in to it. After that I would use it for a while and get to know the care and feeding of that little beast operationally to establish a baseline.
Furthermore... down the road:
I would only bother to use PTC thermistors if solid stating the power supplies.
I would not worry too much about removing that cap across the secondary, I think everyone does that one.
The turbo-mod is one I've never tried yet because it is written rather vaguley and Tim has told me on many occasions if done wrong you can instantly zorch your mod transformer.
Negative feedback is another area to play around with later on as well, but some folks think it's not necessary and you will find lots of opinions on that as well, especially from the audiophile crowd.
Have fun.
