April 26, 2024, 08:11:03 PM *
Author Topic: VIKING2 OUTPUT LOW, THEN CREEPING UP...  (Read 5208 times)
ve6pg
« on: November 23, 2010, 06:37:08 PM »
..hi from tim...my viking2 when i throw the plate switch, has abt 50 watts output, low grid drive, then creeps up to where it should be...this takes about 30-40 seconds....then all is fine...plate current, drive levels etc...
...any ideas?..
tnx..
..sk..
n2ry
« Reply #1 on: November 23, 2010, 07:11:12 PM »
check both 5r4gy's, same thing happened to my dx-100b, i had a non working 5r4gy, filament went and it was stone cold, took the one left a bit to get up to speed
rich
n2ry
KA0HCP
« Reply #2 on: November 23, 2010, 07:15:00 PM »
It's a sad tale we often hear this time of year.......'slow electricity'.
Try leaving a circuit cracked open so the electrons can flow, and open the door on the circuit breaker panel.
Good luck!  Smiley
« Reply #3 on: November 23, 2010, 07:55:38 PM »
My bet might be one of the following:
soft 6146's
soft 6AQ5 RF driver tube
LV B+ problem
If the above three items were OK, and the HV B+ was sagging, then the 6146 grid drive would be plentiful from the start.
Also try it with a crystal if using a VFO.
My 2 cents,
Online Online
« Reply #4 on: November 23, 2010, 08:53:52 PM »
I would add one thing to Jim's excellent list:  check the parallel mica caps that couple the driver to the final grid.  These are prone to failure.
« Reply #5 on: November 23, 2010, 10:24:09 PM »
Check the 18 K resistor in the VFO. Last one I did measured 40K and still worked.
W1AEX
Un-smug-a-licious
Apache Labs SDR
« Reply #6 on: November 24, 2010, 02:18:36 PM »
Yup, when my Viker had wandering grid drive last winter, it turned out to be the 18k Chernobyl resistor, which actually crumbled when I removed it to install its much huskier replacement.
« Reply #7 on: November 24, 2010, 08:41:49 PM »
Could that not be checked by subbing a Xtal and see if grid drive comes back up?  That would half split the problem VFO or VIKER
