April 28, 2024, 10:22:56 AM *
Author Topic: R390A B+ PROBLEM  (Read 7586 times)
« on: November 12, 2010, 12:33:24 PM »
Well I got the receiver back together again after replacing a screw in the gear train and realigned all the cams and set off to testing it. All was working well, I had good reception now on both ends of each band. I was trying to tune in some guys on 160 when all of a sudden the audio went away. I checked the B+ fuse and it  was blown.
So I checked the wiring at the fuse. It's reading about 17 meg ohms back into the supply so that's OK. I checked from the other side of the fuse which is the B+ buss and it reads a low 217 ohms. That's my problem, what could cause this low resistance?
Any ideas would help. It hard to find a straight through schematic of the receiver to look for the obvious. I remember reading something about the alignment of a certain wafer switch. I'll try turning the MC dial and see if the short goes away.
Edward Cain
« Reply #1 on: November 12, 2010, 01:32:32 PM »
Several years ago I had a similar problem after removing the front panel of an R390A. It turned out that I had pinched a wire between the panel and chassis when I reinstalled it panel.
Ed
« Reply #2 on: November 12, 2010, 01:44:20 PM »
Ed
You may have a point, sometime you only need to look back at the last major thing that was done. Maybe later tonight, I'll loosen it up while watching the ohm meter.
« Reply #3 on: November 12, 2010, 02:01:41 PM »
Unplug the connectors to each module one at a time.  That;ll narrow it down to the module, if you don't find a pinched wire on the front panel.
N8ETQ
Mort
« Reply #4 on: November 12, 2010, 10:47:51 PM »
  Yup...
Posted by: Edward Cain
Insert Quote
Ed
Me too..
/Dan
« Reply #5 on: November 13, 2010, 05:28:36 PM »
It turned out to be the plug in filter capacitors. does anyone know a supplier?
« Reply #6 on: November 13, 2010, 06:17:25 PM »
Hayseed hamfest
http://www.hayseedhamfest.com/
« Reply #7 on: November 13, 2010, 08:47:11 PM »
Those caps look great! Thanks. There is room to put caps under the chassis but I think they would run cooler on top. I think by the time I purchased all the caps it would be close to the total they want for the cans.
WV Hoopie
« Reply #8 on: November 13, 2010, 09:00:31 PM »
If that R-390/A still has old caps, better leave it unplugged. All the electrolytic caps by this time are kaput and the BBOD's are crap.
33uf @ 350V    140-XRL350V33
Xicon
The above will fit inside C603
47uf @ 350V    140-XRL350V47
Xicon
The above will fit inside C606; all of the above can be ordered from Mouser. Then there is the cap, C609, that rots the audio board, it is full of sulfuric acid. Plus the electrolytic bath tub cap C103 on the back panel will need attention also.
73's
Craig
« Reply #9 on: November 13, 2010, 09:38:24 PM »
Thanks Craig, I'll look at your suggestions tomorrow. Me going to bed Tongue Tongue
« Reply #10 on: November 13, 2010, 10:37:31 PM »
WOW crapola caps overnight.
I replaced mine for the helluvit a year ago and it was like a new radio. It just seemed like performance took a huge jump.
You can get the type with AXIAL leads and stuff underneath the audio chassis. And leave the cans intact. There's not that much heat under there to be concerned.
« Reply #11 on: November 14, 2010, 11:40:30 AM »
AXIAL CAPS
Where would I find them at a reasonable price?
Edward Cain
« Reply #12 on: November 14, 2010, 12:15:00 PM »
Try justradios.com.
« Reply #13 on: November 14, 2010, 07:39:47 PM »
JustRadios, is the place to buy, speaking of buying there is an R-389 on Epay now. Never heard of one of those. Must be a bear on LF.
