March 10, 2026, 02:11:34 AM *
Author Topic: HP-8640B problem  (Read 7349 times)
Edward Cain
« on: October 08, 2010, 03:28:05 PM »
I just picked up an HP-8640B opt. 323 signal generator. Looking at the output (modulation off) on my scope (sweep rate at 5ms/div), I see the waveform in the attachment.
Any ideas as to where to look first?
Thanks,
Ed
« Reply #1 on: October 08, 2010, 03:43:21 PM »
Check the power supply for ripple. Pull the regulator card and reinsert it.
I had one with messed up power and it worked fine after I cycled the card.
Paid $100 for it and a late model to boot. Also could be an issue with ripple on the leveling. I think in the box the output amp is located in. ECL power to the divider section could also be an issue. I would take a look at the cavity output on a spectrum analyzer if it isn't the power supply. I had a cavity with the screw threads loose on the cavity lid front section that made a weird waveform.
« Reply #2 on: October 08, 2010, 08:52:38 PM »
Thats the USAF model AN/USM-323 and it doesnt have all the features of the commercial model such as phase locking the cavity.
I have the same model and suddenly had a lot of broadband noise on the signal. Reset a bunch of boards and its been fine.
« Reply #3 on: October 08, 2010, 09:05:32 PM »
Carl,
Many mil 8640Bs lived ther lives sitting on the floor with the face up. I read that in time the grease from the lead screw flowed down into the cavity making them unstable or stop oscillating. I agree on cycling the board connectors. Edge connectors get tarnished. At least HP used good plating on the contacts. Never take an eraser to them.
« Reply #4 on: October 08, 2010, 10:48:19 PM »
I'd like to find me a nice 8640B  Shocked
Edward Cain
« Reply #5 on: October 09, 2010, 01:07:04 AM »
Thanks for the response GFZ and Carl. I tried reseating all the boards that can be reseated with no luck. What ever is happening seems to be happening at about 60 Hz so I think I'll concentrate on the power supply. I'll look for ripple first.
Forgive my ignorance GFZ, but what is ECL that you refer to?
Thanks again,
Ed
« Reply #6 on: October 09, 2010, 06:47:18 AM »
The 8640B cavity oscillator tunes about 250 to 500 MHz. Emitter coupled logic  is a string of high speed divide by 2 flip flops to divide the operating frequency down to the lower bands. The waveform coming out of the dividers is not a perfect sine wave but close. I think there is some filtering  in the divider section. I hope that isn't your problem because it is a trip to deal with the cam switches. 60 hz I would look at the power supply. May have an open diode, Then I would look at the modulator section.
Edward Cain
« Reply #7 on: October 09, 2010, 10:44:25 AM »
GFZ,
   I found a bad cap in the power supply. It's a 3900 uF at 50 V which I'll have to order (luckily found an exact replacement). I hope this is the only problem. I'd hate to get involved with the ECL (thanks for the explanation).
Ed
« Reply #8 on: October 09, 2010, 12:50:30 PM »
A larger value is ok as long as the voltage is the same or higher. not critical
« Reply #9 on: October 09, 2010, 11:21:34 PM »
Any time one  shows a pic of "ripple" it would be nice to know if the period is 8.3 ms (120 hz) or 16.7 ms(60 Hz).
I assume you have a manual.  If not, short of reseating boards solving the problem, you will need one.
Al
Page created in 0.041 seconds with 15 queries.
