June 25, 2026, 11:22:14 PM *
Author Topic: diode stack  (Read 16539 times)
« Reply #25 on: September 30, 2010, 08:49:23 AM »
I always go 4 times the ac voltage of the transformer with each leg of the diode bridge. I also use 6 amp 1kv diodes from MCM Electronics.
 "6A10 - Rectifier 6A 1000v SI R-6" http://www.mcmelectronics.com/search.aspx?K=6a%201000&T=R&T=R  It's worth a little extra money for heavy diodes to never have to worry about them. On real heavy stuff I double them up.
John N8QPC
Mouser had some difficulty with 6A10 diodes some time back and got them listed as 6Amp 100piV ratings .... a phone conversation with Mouser customer support seemed to go like "We have BOTH ratings in stock" .... I tested both types obtained from Mouser with a hypot tester and found the avalanch point for both at approx 1200V inverse ....
It seems to me that however many diodes you choose to use in your stack that I would test the piV before ya use 'em
« Reply #26 on: September 30, 2010, 10:06:09 AM »
Wow, you seem aweful confident   There is an ambiguity in this discussion... we don't actually know if it's 4600VCT or 4600V either side of center
I am confident.... their is no ambiguity as the voltage was established earlier.
If there is any question about the accuracy of this information, I will be happy to go through the proof, step by step if necessary
Bring it on but Id suggest you at least read what you posted earlier first.
« Reply #27 on: September 30, 2010, 10:26:25 AM »
5 per leg of the 1N5408's is more than sufficient as that will give you 10KV PIV in each pair of a FWB.
Carl,
       Isnt a 5408 rated 3A / 1kV ?? If so you need more than 5 per leg of a FWB for 10kV PIV, or am I having a brain fart??
Both conducting sections are used so you have 10 diodes in the active path and 10 more in the reverse path.
I think this horse is dead  Grin  But, as Ross Perot said "I'm all ears" in hearing an explanation of what was said above.
Page created in 0.027 seconds with 18 queries.
