March 10, 2026, 01:03:42 AM *
Author Topic: Viking ll VFO socket  (Read 2445 times)
WB4AQL
« on: September 12, 2010, 06:36:28 PM »
Hello everyone,
I`ve got a Viking ll that previous owner swapped from the original 8-pin to 9-pin. I`m trying to make the 122 VFO work with it. I`ve got the VFO working, but it won`t shut off-it`s blanking the receiver. Does anyone know a common reason for switching to a 9-pin? Can`t think of a reason why anyone would go to that much trouble. I`m trying to figure out the wiring mods. The xmtr is not butchered and looks original except for the plug.
Does anyone have an original 8-pin plug for sale or know of a source?
Thanks,
Mike WB4AQL
« Reply #1 on: September 12, 2010, 08:56:12 PM »
Mike,
If used with the Johnson 6N2 transmitter (for transmitting on 6 and 2 meters), the Viking 1 and 2 VFO socket is changed to a 9 pin to provide filament, B+, and modulated HV to the 6N2.  It sounds like this was done to yours.  Grab the 6N2 manual from edebris and that will provide the info you need.  I would leave the socket as is and wire the VFO cable to match.
Pin 8 (VFO end) is the keying line on the VFO-122 and when it is grounded the VFO is keyed so right now it sounds like this is connected to an always grounded line.
In short, the VFO-122 plug (transmitter end) should be wired in the following manner:
white filament leads to pins 7 AND 8
red/white (low B+) to pin 4
braid (ground) to pin 9
black/white (cathode keying) to pin 1
WB4AQL
« Reply #2 on: September 14, 2010, 10:16:12 AM »
I think you are exactly right. I`ll get the 6N2 manual. He also wired the antenna relay socket so that if shorted it will key Viking 2 plate voltage. I want to change that so that it will provide 110V to an antenna relay when plate voltage switch is applied,
Once I understand, things get simpler!
Thank you!
Page created in 0.06 seconds with 17 queries.
