June 26, 2024, 11:23:41 AM *
Author Topic: A receiver preamp that straps :)  (Read 4515 times)
« on: September 04, 2010, 07:37:31 PM »
For those of you trying to avoid getting an energy star rated shack, this is the VHF preamp for you!  It probably draws around 300 watts total between filaments, fan, B+ needs, transformer loss, etc.
* preamp.pdf (1278.06 KB - downloaded 354 times.)
Bill, KD0HG
304-TH - Workin' it
« Reply #1 on: September 04, 2010, 07:56:20 PM »
For a long time I've had a project in mind, a regen receiver using an 833-A.
Maybe, finally this winter.
I did once build a GG preamp for FM broadcast using a WE 416 I got out of some surplus C-Band telephone gear, it worked great, yeah, prolly pulled 50 watts.
Thanks for the posting.
WB2EMS
« Reply #2 on: September 04, 2010, 11:34:54 PM »
Reminds me of when I worked for a company that built some of the hardware for the LAMPS anti-submarine warfare system. The sonobouy receivers festooned on the P3 Orion's had a pretty rough RF environment to work in. To operate without being driven non-linear by nearby transmitters they had a 2N3866 transistor, more commonly used as a final amp in 2 meter HT's, as the first RF preamp. It had about 150 ma of standing current running through it, and a heat sink as I recall. Not as hairy as a 2C39, but still pretty stout.
73 de Kevin, WB2EMS
« Reply #3 on: September 05, 2010, 03:00:49 AM »
I like it, good front end protection too.
« Reply #4 on: September 05, 2010, 11:11:03 AM »
He must have run that into a SCR-522, any other radio would have blown its input stage.
And dont try it ahead of any SS.
« Reply #5 on: September 05, 2010, 06:16:25 PM »
Bill,
I look forward to seeing results and photos from that project.
Are you going to write an ER article on choosing the best transmitting tube for a regen?  Smiley
vincent
« Reply #6 on: September 14, 2010, 08:26:57 AM »
About the use of the 2C39A tube also as a low noise receiver amplifier.
The Boonton 230A (later HP230B) uses 3 of these tubes.
« Reply #7 on: September 14, 2010, 11:18:29 AM »
In the early days of VFOs, right before WW2, some people tried using transmitting tubes like the 211 as the oscillator tube.  The idea was that a transmitting tube had so much dissipation rating relative to the power of the oscillator circuit, that when running as a low powered oscillator (real VFO, not a one-tube self excited oscillator transmitter), the tube's temperature would not change significantly.
I suspect the results were disappointing, since after the initial warm-up most VFO drift results from rf heating the coil and capacitors in the tuned circuit, not from rising tube temperature. The normal warm-up of a 211 would likely cause much more drift than that of a 6C4.
Solid state VFOs tend to be more stable mainly because the oscillator usually runs at a lower power level than that of a tube type oscillator.
« Reply #8 on: September 14, 2010, 09:32:15 PM »
I had one of those. The one I had called for a special version tube with a smaller anode radiator.
