April 28, 2024, 08:06:08 PM *
Author Topic: Modulation Question  (Read 18263 times)
sndtubes
« on: August 20, 2010, 10:49:40 AM »
Hi All,
Sorry but I've got a stupid question ('cuz I'm stupid!)  I haven't played with AM very much and am just now getting my feet wet.  I picked up a HB 2X813 X 2X813 rig recently.  The 813 modulator tubes are triode connected.  The mod iron is a UTC VM4.  The mod deck has negative cycle loading.  The audio and the RF come from a Johnson Ranger.   I bought both the TX and the Ranger together, so they are "matched".  I witnessed the combo giving a full 100 percent modulation on a scope while putting out 350 watts carrier at the guy's QTH.  Now that it's at my place, I can only seem to get about 75 percent modulation or so (per the scope).  I just don't know where to start.  Any ideas of where to start looking or what could be different?  73, Mike WB0SND
« Reply #1 on: August 20, 2010, 11:08:05 AM »
How does the pattern look?  Did the leads get flipped from ranger to mod deck?  Maybe its going 100 neg now and 75 pos. Calibrate the scope.  The thing should go 4 lines high for 100 % if carrier is 2 lines.  The carrier should not close all the way and should still see a small carrier signal there at 75%. If it closes all the way to a thin line, Then its 100% neg.
Post some pictures. We all want to see the rig!
« Reply #2 on: August 20, 2010, 02:03:33 PM »
Final grid current low?
« Reply #3 on: August 20, 2010, 02:54:33 PM »
You could be getting RF into the audio. Make sure you have a good ground on the rig.
sndtubes
« Reply #4 on: August 20, 2010, 07:48:10 PM »
How are you sampling the modulation envelope? Are you using a "tuned" sampler or are you viewing a trapezoid pattern?
I'm using a Heathkit SB-610 monitorscope.  It's just in the output circuit of the amp.  I'm not using the trapezoid pattern, so it must be the "tuned sampler".  I'm not seeing the envelope hit the "baseline".  It's only about 75 perecnt or so.
It think there is plenty of grid drive and I'm showing the typical 20 mA or so of grid current.
I'm also seeing about 30 mA of screen current and 300 mA or so of plate current.  It all looks normal to me, but just not 100 percent modulation.  Listening to the audio from the transmitter gives the feeling that it's "light".
I will check the grounding as that may be the source of the problem.  My 120 circuit in the shack is an old 2 wire circuit, so I'm running a short piece of #10 out to a ground rod outside the shack as well as another one to a cold water pipe in the basement.  I will be rewiring the shack soon.
thanks for all of the suggestions so far.  Keep 'em comin' !
« Reply #5 on: August 20, 2010, 08:00:58 PM »
It wont hit baseline if it has neg peak limiting..  Calibrate the scope, Then hit the transmitter with audio. See what the pos peaks are.
sndtubes
« Reply #6 on: August 20, 2010, 08:55:28 PM »
Ha.  I'm starting to think that maybe nothing is wrong.  It does have neg peak limiting.  I'll do as you describe in your first response and report back.  It might be a couple of days though.  I will also post a picture of it.  It's pretty cool, but nothing extraordinary.  I was doing some testing with a local friend of mine, W0HRO, Ken, but it might not have been a good test as he's about 25 air miles from me which is kind of iffy on 75 meters.  I may need to get some reports from 200+ miles away.
Ralph W3GL
« Reply #7 on: August 20, 2010, 09:09:27 PM »
    Something else might be at work here, as well...
    You state your 110 is an "OLD 2 wire" circuit.
    Check your line voltage under load, could be
    the voltage is sagging.  Might need to upgrade there...
73,  Ralph  W3GL
« Reply #8 on: August 20, 2010, 09:23:58 PM »
Ok cool..  Your on the right track now..  Thats also a good suggestion to check line voltage. The King only does 250 watts and about 80% mod on a wall socket.  On a seperate 30 amp line it does 300 to 350 and 110 pos.
sndtubes
« Reply #9 on: August 20, 2010, 09:46:56 PM »
Absolutely NO question my line voltage is TERRIBLE.  Sometimes it's as low as 105 volts under NO load.  The power supply has 3 taps on the primary.  105, 115 and 125 VAC.  It was connected to 125 VAC, so I changed it to 105 VAC.  Big mistake.  Shortly after that, I had a parasitic oscillation in the final and it blew the screen regulator transistor.  Maybe it was a coincidince.  At any rate, I have it back where it was.  I will definately be upgrading the wiring to the shack in a few weeks.....
sndtubes
« Reply #10 on: August 24, 2010, 12:13:47 AM »
Update.  I had the transmitter RF routed through switches and the scope was also in line but routed through switches and t/r switches.  Tonight I hooked the scope directly to the  transmitter and then to the dummy load.  I now observe I can easily get to 100 percent modulation, reaching baseline with very little driving audio.  So, it now appears to work as it should .....well maybe.  I do observe that the power does "dive" rather dramatically on modulation peaks.  If the transmitter is loaded to 350 watts carrier, I see the carrier dive to about 275 to 300 watts on peaks.  I also see the plate current take a corresponding dive.
Is this due to the poor line voltage or could I have something else wrong?
* 813_rig-2.JPG (0 KB - downloaded 208 times.)
N0WEK
« Reply #11 on: August 24, 2010, 12:20:00 AM »
Nice looking rig!!
Bet it does better with a stiffer AC line and good grounding.
W7SOE
« Reply #12 on: August 24, 2010, 04:54:44 PM »
That is a good looking transmitter.  More pictures!
Rich
« Reply #13 on: August 25, 2010, 02:30:25 PM »
Ive run across many plugs and connectors holding on by a strand or two, does wonders for the regulation.
« Reply #14 on: August 25, 2010, 03:14:57 PM »
Put a meter on the wall socket to confirm.. But I am going to suggest that its simply the lack of power.  This transmitter cant run properly on a lamp socket.  I was in the same boat with the GK500C and the T368.  I had a 30 amp line run with number 10 wire to a 30 amp 120 volt plug. The King and T368 came to life.
Your choice is to run a line for this rig OR you are probably better off loading it lighter.  Dont load it to light or you could damage the iron.  But experiment and try 230 to 250 watts carrier.  Adjust Grid Drive while putting audio into the rig. The second more Grid does not increase peak output power, Its set. You could be underdriving the Grid so use that method.
What a neat old rig you got man!
sndtubes
« Reply #15 on: August 27, 2010, 02:23:02 AM »
Oh, I know the power is inadequate.  During the heat in the past few days, line voltage was running about 105 volts.  I have an expanded scale line voltage monitor on the socket.  What I am doing temporarily is I'm running it off of one phase of my 220 circuit I have in the shack.  It runs much better off of that circuit.  I seem to be getting 100 percent modulation now, but still having some sag causing the power output to sag a bit on voice peaks.  This is at 350 watts carrier.  The transmitter will put out in excess of 400 watts, but I dont' want to zorch the thing.  Nonethess, I made a couple of QSO's with it and got good audio and signal reports, so I think all is well now.  I'm going to put in a real stout dedicated 110 volt line sometime in the next few weeks.  Thanks for everyone's help.  Boat anchors rule!!
« Reply #16 on: August 27, 2010, 09:28:39 AM »
#10 wire is your friend
Fred k2dx
« Reply #17 on: August 27, 2010, 09:59:34 AM »
If you can get a step up/down transformer it might help with your present wiring. Using your 220 line, step it down to 110 right next to the rig, then use a good heavy line cord on the rig. It will do wonders with your voltage regulation.
Look for 110/220/440 transformers, they are rated in KVA. I use a 5 KVA transformer with my T368 which is 110 only.
sndtubes
« Reply #18 on: August 28, 2010, 10:20:35 AM »
Thanks for all of the good suggestions.  I am going to put in a new circuit soon.  I will use #8 or #10 wire.  I'd like to use #8 because it's a pretty long run.  It will probably cost more that the transmitter for the wire!  I will report my results when I get it done.  It will probably be a few weeks though.......
Right now I am running it off of one leg of the 220V circuit in the shack.  Nothing else is on while this transmitter is on.  Seems to work much better.  There is a 105, 115 and 125 volt tap on the primary of the power transformer.  It was on the 125 volt tap and I switched it to the 115 volt tap since my line voltage is much closer to that value.
I now can get a full 350 watts carrier with 100 percent modulation, but there is that sag on peaks.  Power dips about 50 to 75 watts on mod peaks.  That should be much less when I stiffen the line.  Since the modulator is being run with the same power supply as the RF deck, I would expect some sag.  I have some highly regulated Kepco power supplies here but may not be quite enough for the job.  They are 0 to 1500 volts at 200 mA.   I thought about trying to run the modulator off of one of these supplies and seperate the modulator from the RF deck, but I don't think they are quite heavy enough.
I will post some more pictures soon.  It really needs to be "repackaged" to be pretty.  At the very least, a paint job.  The transmitter was originally started as a project by one guy.  He did kind of a hack job and didn't finish.   It was then purchased by another fellow who finished the job and got it working very well.  It's kind of like my 1930 Buick.  It looks great from about 20 feet at 20 mph.  But when you get close, it's a little homely.  But, over time, I will try to pretty it up.
At present it operates on 160, 80 and 40.  I wouldn't mind putting it on other bands, but the fellow who completed the job claimed it would not work well on the higher bands.  I'm not sure why that is as the 813's are rated at full power up to 30 MHz.  Any ideas there guys?
73, Mike WB0SND
« Reply #19 on: August 28, 2010, 03:20:33 PM »
The 813 has a quite large plate capacitance that can make it difficult to tune under some operating conditions at high frequencies.
« Reply #20 on: August 31, 2010, 10:54:52 AM »
Look at the old SSB handbook on 813 amplifiers. on 10M a small amount of L was added between the coupling cap and plate tune to deal with high plate C.
High plate C drives the Q high on 10m and makes it hard to tune with a plate cap with high minimum C. You end up making the inductor small to get it to resonate. circulating current is high so there is high loss. Very layout critical but they will play on the higher bands
« Reply #21 on: August 31, 2010, 03:13:57 PM »
They will work on 10 like the guys say. I have seen LOADS of CB amps on 11 with 813s on Fleapay.  There used to be a guy on there that sold 1, 2 and 3 tube "no bandswitch" amps.
sndtubes
« Reply #22 on: September 01, 2010, 11:55:07 AM »
Thanks for the info, guys.  I may try to get it to play on the higher bands this winter.  No hurry yet as we STILL dont' have enough solar activity to do anything higher than 20 M.  There are 3 or 4 positions left open on the bandswitch, so adding extra bands should be able to be done.  I'll look up the earlier threads and the handbook articles.  I'll probably have it on the air tonight for the Collins CCA AM night on 75.  I normally use the 32V2, but it will be fun to use the big rig.  I'll use the 75A-4 or 51J-4 so I'll still be kosher for the Collins net.
« Reply #23 on: September 01, 2010, 02:41:20 PM »
If you make the 10M coil as calculated and then place the Tune cap dead center it will require 4X the C to resonate.  That method goes back ages for commercial SW amps. You can also locate the cap tap elsewhere as desired.
My 4 x 813 amp runs fine on 10M.
Modern hams are "rediscovering" that principle with amps using the YC-156 and other hi output C tubes.
« Reply #24 on: September 01, 2010, 03:43:37 PM »
There are 3 or 4 positions left open on the bandswitch...
Something to think about if you have this problem:
Depending on how far apart the switch tabs/contacts are on the bandswitch, you may have arcing between them under heavy plate modulation. If so, then use every other tab to increase the spacing. Since you have extra tabs, it might be the only way.
On my 4-1000A plate modulated rig, I used every other tab and STILL needed to paint on some corona dope to tame it. It seems shorting the coil from the loading capacitor end is the only way to get to 40M and above without arcing. If you tap the coil without shorting it, the Tesla coil effect is too much and arcing is sure.
I've run tests and find the slightly lowered Q and small power loss from shorting the coil is not excessive. The other alternative is to use plug-in coils. (All whirl class amplifiers use plug-in coils according to one amp guru I know...) Grin
Page created in 0.104 seconds with 18 queries.
