March 09, 2026, 11:26:58 PM *
Author Topic: 2 kW transistors  (Read 4207 times)
John K5PRO
« on: July 18, 2010, 02:44:57 AM »
Silicon Carbide FETs from Microsemi can produce about 2 kW pulsed at 15% duty factor at 200 Mhz now. Vdd is > 100 VDC. Finally something that can replace a tube with respectable Pout.
« Reply #1 on: July 18, 2010, 07:28:27 AM »
What's the price tag?
« Reply #2 on: July 18, 2010, 10:10:11 AM »
If you have to ask you cant afford them Shocked
« Reply #3 on: July 18, 2010, 10:14:19 AM »
That's the point exactly....
Fets that handle 1 to 2kw are nothing too new, they've been around a few years.
But most of them cost over $1k each
Not exactly "experimenter's devices"
 Wink
W1ATR
Resident HVAC junkie
« Reply #4 on: July 18, 2010, 10:23:06 AM »
 Wink
Right, and a slight mistake in the circuit buildup and those nice little kilobuck doodads let off a flash like a Romulun disrupter haha.
Buck a watt for a delicate fet or 40 cents a watt for a durable toob. hmmmm (20 cents a watt on the bigger toobs)
Jared W1ATR
Click for radio pix
« Reply #5 on: July 18, 2010, 04:33:46 PM »
VHF and UHF devices ~ price around $1400 each in single lot quantities.
John K5PRO
« Reply #6 on: July 19, 2010, 02:07:46 AM »
Correct, price is less than 2 kilobucks per device. All the new kW level devices so far are 50 V LDMOS parts, these are 120 Volt wide bandgap devices, so they run high temperatures and matching is quite simple. Since we are building a 5 kW brick at work, then going to make a 25 kW unit, this is quite cheap, compared to trying to combine many lower power devices.
I doubt us hams could afford it, but these are the bellweather of things to come. I reckon that thermionic devices under a kW will eventually be rare except for the seemingly plentiful supply of NOS glass tubes like 813s and 6146.
