May 11, 2024, 09:27:50 PM *
Author Topic: SDR learnin  (Read 4027 times)
David, K3TUE
Per-spiring AM'er
« on: July 13, 2010, 10:56:54 PM »
I have been churnin through a number of old posts here about different SDR options. The last best opinion I got from Frank/GFZ was that the QS1R from Phil Covington looks like the best available to date. It had looked like Phil had trailed off in his effort with the QS1R, but I see a recent update to his blog about availability, so I guess this is encouraging. But I suppose I should start with a SoftRock SDR like everyone else seems to have done.
I read somewhere in this searching someone made mention of a good article that Steve/HUZ posted about SDR, which I can't seem to find. Does anyone know the URL of this article?
David, K3TUE
« Reply #1 on: July 14, 2010, 02:05:52 PM »
I have the link at home but my commute this week is 3000 miles.
Softrock on an IF is a great place to start cheap and learn how to use the software.
Hold off a while longer on spending money. HPSDR Hermes is almost done. The PC board is in redesign to eliminate some ground loops that caused a few RX spurs.
This is the same performance as the QSR1 but it is a transceiver that makes 1/2 watt.
Steve's article is very good.
« Reply #2 on: July 14, 2010, 02:54:37 PM »
You also have the Flex 1500™ QRP HF+ 6 meter software defined transceiver for less then $650.
http://www.flex-radio.com/Products.aspx?topic=F1.5k_features
Page created in 0.046 seconds with 19 queries.
