May 18, 2024, 12:51:06 AM *
Author Topic: Not Biased, Yet  (Read 2361 times)
Barrie
« on: May 11, 2010, 07:38:51 PM »
The ongoing saga of the push-pull VT-127As continues.
I've got most of the chassis metalwork done.  All major components are mounted.
Now, I'm looking at the bias supply.  Several sources indicate that the VT-127A requires -340 volts bias for class C CW.  No mention is made as to what the bias should be for plate modulation.
If the bias requirements are similar to the 100TH (which I think they are, judging by the rather high voltage involved), then I think I could use the same factor to determine the AM bias for the VT-127A.
The 100TH calls for -225 volts bias for CW and -400 volts for AM.
The -400 volts is 1.77 times the CW voltage.
If I multiply the CW bias for the VT-1127A by 1.77 I get -600 volts.
Even to the unwashed and uneducated (me), that seems like a lot of minus volts.
Any washed and educated thoughts on this subject?
73, Barrie, W7ALW
« Reply #1 on: May 11, 2010, 10:31:25 PM »
Could it be more like the 100TL? Check the data for it here. The AM PL data and class C data sort of reflects what you have posted. But I am not washed enough to really answer. If it were me and there was no data I would equip a temporary bias supply and test, then build the proper one. All my stuff has variac controls, so either way it would be OK.
* 100TL.pdf (409.17 KB - downloaded 168 times.)
« Reply #2 on: May 13, 2010, 08:08:27 PM »
I saw a reference to the VT-127A having a Mu of 15.5. I also see a condensed data sheet here:
http://www.nj7p.org/Tube4.php?tube=VT-127A
Class C Amplifier
Plate Voltage ................................. 2000 V
Grid No. 1 Voltage ............................ -340 V
Grid No. 1 Current ............................ 67 mA
Plate Current ................................. 210 mA
Driving Power ................................. 25 W
Power Output (approx) ......................... 315 W
Doesn't say anything about AM though, but the above conditions should be a good place to start.
You can look at 100TL (Mu-14), and 100TH (Mu=38) at this web site:
http://www.scottbecker.net/tube/sheets1.html
Barrie
« Reply #3 on: May 31, 2010, 01:48:53 PM »
I've gone ahead and built a variac controlled bias supply, so I have 0 to 680 volts.
My only problem now is how to attach it to the tubes.  I see a method in a 1955 handbook that looks pretty simple.  I've enclosed a rough schematic.
In this circuit, it looks as if the grid resistor will also act as a bleeder for the bias supply?
What value should the RFC be?
Should there be a by-pass capacitor on the bottom of the RFC?
Any help appreciated.
73, Barrie, W7ALW
Page created in 0.041 seconds with 17 queries.
