March 10, 2026, 11:28:32 PM *
Author Topic: Refurb Ranger I  (Read 11176 times)
natanw6xr
« on: May 04, 2010, 09:45:45 PM »
I picked up a completely refurbished Johnson Ranger I at NearFest and I'm having a bit of a problem getting the Ranger to operate a Dow Key Relay.  My plan was to use the 110 V available at the ceramic socket on the rear panel when the PTT is actuated.  The socket looks like it will accept a FT243 xtal holder but the pins are too large to fit.  So what might be plan B to energize the Dow Key to mute the RX and change the coax from the rx to the transmitter.  Ideally, I want to minimize cutting or beavering (a technical term) the chassis given the condition this Ranger is in right now.  I'm sure there is a simple solution I am once again missing.
Thanks,
Natan W6XR
Freeville, NY
W1GFH
« Reply #1 on: May 04, 2010, 10:37:26 PM »
Yank two pins from an old tube socket and solder them to the ends of a short length of zip cord. Nicen up the joints with heatshrink tubing. Perfect fit for the Ranger's 110V relay socket.
« Reply #2 on: May 04, 2010, 11:10:48 PM »
FT-243 crystals will not fit into that crystal type holder. Find an old HC6/U crystal. Many of the old CB crystals were this. Unsolder the housing from the base. Gut the crystal stuff. Solder an insulated wire to each pin, punch or drill a hole in the top of the housing, slip the wires through the hole, and then reassemble and tack solder the housing back to the base. Add a piece of masking tape around the housing for insulation and gripping. "Old timers" used this technique and I think something similar was once published in Hints and Kinks.
« Reply #3 on: May 05, 2010, 06:59:32 AM »
I have some new white ceramic FT 243 xtal holders  (Millen) if it would fit I'll be happy to send you one.
W1GFH
« Reply #4 on: May 05, 2010, 08:09:07 AM »
The hacked metal HC6U xtal method is a little sporty with 110VAC, but some people like it:
« Reply #5 on: May 05, 2010, 09:31:56 AM »
I use the hacked HC-6U method with all my Johnson rigs.  You might need to spread the pins a little bit to ensure a tight fit.
« Reply #6 on: May 05, 2010, 10:08:04 AM »
Nicen up the joints
The technical jargon on here never fails to amaze me.
w6xr
« Reply #7 on: May 05, 2010, 02:59:33 PM »
There are times when I surprise myself and alas, this is one of those times.  My connector parts box had components of the newer type "N" connector, specifically the center pin!  The tip of the center pin is of course beveled and the body has a hole in it to facilitate passage of hot flowing solder.  So since it fit perfectly into the ceramic socket, I added a slight coating of solder, then flowed solder to my wire now placed into the body of the center pin and I had a fine business connector for powering my Dow Key relay.  The cost was minimal and the connection can be tight, permanent or damn near permanent.  Put some shrink wrap on the wire and center pin and it even looks fine biz too.
So maybe tonight I can try out the new Ranger, assuming all else is just fine business!
Thanks to all who suggested the various resolutions to my simple problem.
Natan W6XR
Freeville, NY
« Reply #8 on: May 05, 2010, 08:47:37 PM »
Fyi, I don't bother to mute my receiver... the isolation from the Dowkey is enough to make the signal from my hotrod Valiant2 to about 40 over... makes a nice in room monitor... keep the speaker back about 7-8 feet... the Ranger is lower power so should be fine... might be worth trying...
 Btw, nice meeting you at Nearfest!
Cheesy
« Reply #9 on: May 06, 2010, 12:24:55 AM »
it's moot now, but you could probably curl in the edges of the xtal can hole with a unibit or something like it sort of reeming them in so they don't cut into the shrink tubing and wire insulation.
General question--what is so wonderful about the Dow-Key relays on HF and 160?  I am asking because I thought I'd just make up a TR relay with an aluminum project box, 3 UHF jacks and get a DPDT relay with whatever coil v. I need and RF voltage rating and mount it in there and go.  I figure the Z bump at HF won't be a problem will it?  As long as there is no relay chatter from  RF getting into the coil.
If I am missing something you get with Dow-Key pse tell me before I waste time and money of materials and I'll add it to my hamvention shopping list.   I can understand needing one for 6 meters and up.
Rob
Ralph W3GL
« Reply #10 on: May 06, 2010, 12:30:10 AM »
Rob,
   Put  your "relay in a box" on the output of the RF generator
   and your good to go thru 6 meters...
   With a 3p/dt relay you can even do the receiver muting thing!
73,  Ralph  W3GL
« Reply #11 on: May 06, 2010, 07:56:15 AM »
Thanks Ralph that's a great idea!  wish I could think of these things on my own  Embarrassed
Rob
« Reply #12 on: May 06, 2010, 03:11:57 PM »
Rob,
I've been doin that for years with no problems. At 50 ohm impedances and moderate power levels, it doesnt even have to be an RF rated relay. I usually use the bigger (10A contacts) "ice cube" relays. they work just fine!
Rob
Thatz what you got us for! !   Grin  Grin  Grin
W1GFH
« Reply #13 on: May 06, 2010, 06:24:42 PM »
They're really not any better than a hefty open frame contactor relay you can wire up with coax jumpers yourself. The Z bump to the Xmtr is negligible. Some people don't even bother with enclosures or shielding. However, if you come across a Dow Key cheap (or free), they make the T/R wiring at the back of the rig a little faster, neater and more convenient.
W1GFH
« Reply #14 on: May 06, 2010, 08:45:26 PM »
I recall I had one of those. It ran so hot you could fry steaks on it!  Grin
« Reply #15 on: May 08, 2010, 12:18:58 PM »
I have one and it would make a great coffee warmer if it didn't make the coffee evaporate so quickly Smiley  It gets used when I want to quickly pair up a receiver and transmitter without worrying about relay control voltages but it never becomes a permanent part of a setup.  It is one of the few pieces of gear that gets too hot for the cats to love.
Page created in 0.048 seconds with 17 queries.
