December 02, 2025, 03:04:42 AM *
Author Topic: solid state plug in replacement vacuum tube rectifier chart  (Read 12998 times)
« on: May 01, 2010, 07:41:22 PM »
indeed.. Not all are created equal. I found these useful so as to better match the various rectifiers to the application.
* solid state tube rectifier datasheets.pdf (103.8 KB - downloaded 1312 times.)
* solid state tube rectifier datasheets-2.pdf (62.96 KB - downloaded 894 times.)
* solid state tube rectifier datasheets-3.pdf (57.47 KB - downloaded 887 times.)
« Reply #1 on: May 01, 2010, 07:51:59 PM »
I also have a 1N42. This is an octal based device similar in appearance to a 6H6. I have not specifically found the datasheet for it.
The regular 1N42 seems also to be a standard germanium rectifier 115V 12.8mA in a DO- case. Plenty of sheets on that version, but none so far on the tubular one.
Page created in 0.052 seconds with 15 queries.
