April 28, 2024, 05:03:11 PM *
Author Topic: Correcting 3-Diode Limiter Imbalance  (Read 2162 times)
w5hro
« on: April 19, 2010, 04:34:58 PM »
After much analysis the 3-diode negative peak limiter appears to have a significant imbalance. This imbalance can easily cause the diodes to blow which has in fact been the case from various reports through the years. This imbalance is greatly multiplied when modern solid state diodes are connected in series.
Below are 3 simulations of the 3-diode limiter using perfect diodes that show the time durations and currents when each diode conducts.
As you can see both D2 and D3 have a problem because of this imbalance.
Values used for the simulation:
R1 = 6K
R3 = 60K
Continue to the next post ----->
Page created in 0.042 seconds with 16 queries.
