May 03, 2024, 11:01:49 AM *
Author Topic: HP 1740A scope input fet  (Read 3679 times)
AB3FL
« on: April 12, 2010, 10:41:08 PM »
I lost the 'B' channel on my HP 1740A scope.  The 'A' channel works fine.  I traced it to a dual jfet device with hp part number 1855-0217.  This part is made of pure unobtanium.  Does anyone know if I can replace it with 2 regular plain old mpf102 fets? or some other fet.  It is right after the input attenuator and HP refers to the section as the impedance converter.
thanks
Tom - AB3FL
« Reply #1 on: April 13, 2010, 09:01:34 AM »
look at Siliconix parts maybe they still make dual FETs. I think Vischay owns them now. I would think a pair would work but since they are not a perfect match you might have a slight DC offset. U310 is also a good choice.
« Reply #2 on: April 13, 2010, 05:44:40 PM »
Did a yahoo search, and someone else has the same problem, on channel B, in espanol.
Replaced member: JFET DUAL N-CHAN HP part number 1855-0217
(like from maintenance handbook). Sul JFET is written 55-0266.
I'm assuming they mean they SuB not Sul is for substituted.
Maybe you can find that number, it seems to be what that clown did and got his up and running.
KB3DKS
« Reply #3 on: April 13, 2010, 06:24:25 PM »
You might check with Sphere in Canada. A very good source for test equipment parts.
http://www.sphere.bc.ca/
Bill
AB3FL
« Reply #4 on: April 13, 2010, 06:27:31 PM »
I got 2 mpf102's from Rat Shack and put them in.They work fine, at least for looking at waveforms and modulation
thanks all
Tom - AB3FL
« Reply #5 on: April 22, 2010, 08:53:09 AM »
they may or may not make the requisite bandwidth...
the Vishay (Siliconix) is a good idea, since Tektronix used them in the front end of 100mHz scopes for sure.
The duals keep the DC drift down.
