May 06, 2024, 06:48:02 AM *
Author Topic: Modulation driver transformer  (Read 2015 times)
Barrie
« on: April 11, 2010, 12:59:52 PM »
I'm making good progress on a transmitter RF deck and am starting to think about the modulator.
I have everything I need for the modulator except the driver transformer.
I want to use a Bogen tube amplifier for the speech amp.  It has outputs from 4 ohm to 600 ohm.
I know that a lot of fellows use a hi-fi output transformer hooked up backwards to drive modulator tubes.
The tubes I will be using are the VT-127As, which are very similar to the 100TL, with about 2000 volts on the plates.  The modulation transformer is from a BC-610
Using the Bogen tube amp as the speech amp, into a hi-fi output transformer, how do I determine the output impedence of the driver transformer, and the wattage?
Thank you & 73,
Barrie, W7ALW
« Reply #1 on: April 11, 2010, 05:44:44 PM »
Barrie, take a look at this link from my good friend, John WA5BXO:
http://www.qsl.net/wa5bxo/driver1.html
« Reply #2 on: April 11, 2010, 07:58:59 PM »
See:  http://amfone.net/Amforum/index.php?topic=23632.0
Barrie,
Consider a homemade MOSFET solid state audio driver. There are many advantages to this approach. Driver transformer phase shift and other tube limitations are gone. There is even a spot to add negative feedback.
Tom, K1JJ
Page created in 0.112 seconds with 18 queries.
