Another thing that dawned on me was say if I use a counter board from a counter or something is that it would probably behave like an ordinary frequency counter. If I'm using it as the frequency readout for the tuning dial then I can't wait for the stupid thing to lock up to display the frequency. It needs to immediately change as I tune the dial. It says the heath 650 is a frequency display, but I wonder if the change is immediate?
You have complete control of the count time duration and interval. The interval you set between counts determines how quickly the display is updated when you tune your oscillator. Use a longer count to get higher resolution - ie: low-order digits. Simply move the decimal point as you change your time base selection.
I found a rather interesting article in QST for April '74. On page 34 is part II of an article by Wes Hayward, W7ZOI, entitled "A Competition-Grade CW Receiver". He installed a HB counter, using 7-segment LEDs, not nixies, inside the receiver. Most of the receiver sections are shielded, but the counter logic is not. He designed it using a 2.0 MHz clock so the spurs would not lie in the ham bands of interest. Then the novel approach he used was to gate signal from the crystal oscillator to the divider chain, such that the chain was inactive when no count is in progress. The oscillator is the only logic running continuously. This virtually eliminated the interference problem.
