May 06, 2024, 07:18:21 AM *
Author Topic: Sx-28 screen voltage  (Read 1833 times)
kc2etm
« on: April 04, 2010, 01:24:01 PM »
Wondering if anyone knows the proper
voltage off screen divider most manuals say
100v but rogers print says 120v
mine is running 119 right now with a replacement resistor
thanks
fred
Don, W2DL
« Reply #1 on: April 05, 2010, 09:53:56 AM »
Actual screen voltage sounds fine, I'll bet no one could tell the difference between 100 and 120V on the screens under almost any operating conditions. Don't sewat the small stuff, concentrate on the big issues!
Don, W2DL
Don, W2DL
57years a ham!!
« Reply #2 on: April 05, 2010, 11:30:53 AM »
All those old manual voltages are +/- 10% so if the measurments were made at 115 volts input to give 100 then at 115 volts input it would be possible to get 120 volts.  With a bit higher line voltage then that reading will be higher.   Be sure you are using the right kind of meter too.
