May 02, 2024, 05:54:40 AM *
Author Topic: Drake 2C troubleshooting  (Read 2196 times)
iw5ci
I love old radios
« on: March 28, 2010, 09:18:07 AM »
I am trying to fix by myself.
Syntoms:
slight hum on speaker and maximum volume very low
vfo is working i can tune stations over the bands but the reception is just above noise
no meter deflection , the preselector peaks on the correct segment but signal are extremely low, only the strogest may be audible.
ssb is ok because if i ear a station the sound is good, selectivity control works.
AGC is not working as in off slow or fast position there is no difference.
RF gain working as when i deduce it the s-meter goes up.
I have swapped all the tuber with other tubes got from a good working radio, so tubes are ok.
Any suggestion about where to start?
« Reply #1 on: March 28, 2010, 09:36:06 AM »
Check the voltage from the power supply (at C46, C47, and C48); this will give you a quick check of the power supply, the main filter caps and their associated dropping resistors.
If these are normal then I would suggest either checking voltages at the tube sockets or using signal injection stage by stage to check for gain/faults.  Checking voltages will probably be easier in this case.  If those are normal then it is time for a signal injection test because you may have a problem in an IF transformer.
