April 21, 2026, 10:31:48 PM *
Author Topic: What am I doing wrong... my amplifier - won't!  (Read 22502 times)
WB3JOK
« on: March 23, 2010, 09:26:15 PM »
I finally got around to playing with the homebrew amp (in my avatar)... but it won't amplify. It seems to make a pretty good frequency doubler though.  What am I doing so wrong???
Brief circuit description: four 4-125A in parallel. Intended to run in AB1 on 75 and 40m. Input is to the grids with a 1:4 bifilar-wound toroid and a 200 ohm noninductive swamping resistor. Individual bias adjustment pots for each tube from a regulated -150 volt supply. Screen voltage is 450v shunt-regulated by a 4-65A, plate voltage adjustable (variac) up to 3.5 kv. I bought a commercially made plate choke and feed the B+ through it. Output is the usual pi-network except that the inductor is three stacked T200-2 (red) cores insulated with Kapton tape and wound with #12.
There is drive to the grids, easily 100 v p-p with my SB-102 supplying the "carrier" on 7200. The pi-net does resonate at 7.2 MHz, checked with a signal generator and scope, and the inductance of the toroid is correct on my Tek 130 LC meter. Total idling current initially set to 100 ma, increases to 180-200 ma with increasing drive. But the relative power output on the SWR bridge's meter is the same, or actually less, than the input!  Angry
Watching the output (into a dummy load!) on my spectrum analyzer is also bad news - not only is there less energy out at 7 MHz than is going in, there is almost (a few db down) as much 14 MHz...  Shocked
so obviously something is really screwed up, but I can't figure out what it is... any thoughts?
Huh
thanks
Charles
« Reply #1 on: March 23, 2010, 09:57:54 PM »
Charles,
What level of plate voltage and grid bias are you actually using?  In straight AB-1 with 450 on the screen I assume you are running pretty high plate voltage and the 25 mil per tube idling current also points in this direction.  With your 1 to 4 step up, even with 200 ohms swamping resistance your drive should be extremely low.
Can you actually dip the plate current?  What is your screen current showing during this process?
WB3JOK
« Reply #2 on: March 23, 2010, 11:01:16 PM »
I originally intended to use this amp with my screen-modulated ARC-5 transmitter on 40m, which is only about 10W carrier.
The plates are running at 3.2 kv (about 90% on the variac). Not sure what the actual grid bias is, will have to measure.
Could the tubes themselves be zorched? The filaments are lit and they're drawing current and showing a bit of color on the plates. Wondering if I burned up the control grids...
Now that you mention it, I don't think there is much of a dip in plate current at all (although I was tuning for max output, not min plate current). Also the screen current seems to be almost zero. I need to check and make sure the metering circuit is actually working, too.
Will take a look tomorrow when rested. I don't like working around 3 kv supplies with 56 uf capacitors at all, but especially when I have a cold and feel tired!
« Reply #3 on: March 24, 2010, 01:36:58 AM »
I am not familiar with toroids in a tube rig as the L in the pi net at those frequencies but it sure sounds interesting. Could the Q be low for some reason? Beware the screen current that you don't fry them.
« Reply #4 on: March 24, 2010, 08:26:34 AM »
What is the cap values in the pi network? Also how much inductance are you getting with that inductor. Sounds like the tank is set up wrong. You need about 250 - 300pf in the plate tune and 1500 to 2000 uf in the load cap. 8 to 10 uh inductor on 75.
If it makes power on 40 the tubes are fine.
« Reply #5 on: March 24, 2010, 09:09:03 AM »
Any chance for some pics sometimes that helps others help you.
Jack
« Reply #6 on: March 24, 2010, 09:21:31 AM »
Based upon no/shallow dip and no screen current it is probably loaded way too heavily.  Try reducing the loading and try again.  Screen current is the best indicator of resonance in tetrodes and the screen current will peak at this point.
« Reply #7 on: March 24, 2010, 09:55:42 AM »
Tuning on the second harmonic will do the same thing if the stage is acting like a doubler
W9GT
« Reply #8 on: March 24, 2010, 10:03:38 AM »
Also....seems unlikely that all 4 tubes would be bad, but it is possible.  Have you tried just one or two at a time?  If they are in parallel, this should be possible.  Just plug-in one or two and try it.  Of course, input and output capacitance would be lower, but, hopefully you will still be in tuning range.  Also plate current would be proportionally less.  Is the plate coupling cap from the tubes to the Pi net OK?
Just some thoughts...
73,  Jack, W9GT
73, Jack, W9GT
N4LTA
« Reply #9 on: March 24, 2010, 10:10:01 AM »
I have often used toroids in a pi net - It sounds to me like the pi - net is not correct. How did you calculate it and what are the values. Did you measure the toroid inductance?
Pat
N4LTA
« Reply #10 on: March 24, 2010, 10:14:40 AM »
Sounds like insufficient drive for starters.
Hopefully you have a grid meter and its seperate from the screen meter.
Increase drive while watching the RF meter and doing a 2 handed Tune and Load tweak for max. Continue increasing drive until you start seeing some screen current.
Once you start getting the tank to function at the designed Rp then the 2nd harmonic will be down where it belongs.
Ive used toroids for decades as both the L in a Pi as well as the L in a Pi-L and they work fine as Alpha and others have shown since the early 70's up into the 2500W area. I havent gone beyond about 1200W yet.
If the tubes are showing idle current and color they are working. How well needs to be determined but they should be OK on the low bands at least.
« Reply #11 on: March 24, 2010, 10:17:16 AM »
Good point Pat!  There are a number of easy online calculators such as this:  http://www.qsl.net/wa2whv/radiocalcs.shtml
If you have an MFJ analyzer or similar you can use it to measure backwards.  With power  removed, connect the MFJ to the output connector and set it for the middle of the frequency range for the band selected.  Connect a non-inductive resistor equal to the calculated plate load from the common tube anode connection to ground.  Leave all other connections intact so that the tube interelectrode capacitance is still present.
See if adjusting your tune and load controls will result in a proper match indication on the MFJ.
REMEMBER to disconnect the resistor and analyzer before your next power up test!
« Reply #12 on: March 24, 2010, 10:30:43 AM »
   Charles,
If the toroid on the input side has a 1:4 turns ratio, doesn't that mean 1:16 impedance ratio?
When I make broad band transformers like that, I use my Autek RF-1 to evaluate the part across the frequency of interest to see how it behaves. This way I can quickly see if I need a different core, or possibly more turns.
What is the input SWR look like?
WB3JOK
« Reply #13 on: March 24, 2010, 11:19:47 AM »
Wow... thanks for all the input, everyone  Wink
Re: the pi-network, the plate tuning cap is air-variable 300 pf, the  inductor measures at 8, 11 and 16 uh (3 taps) on my Tek 130 LC meter (140 Khz), loading is a 1000 pf vacuum variable with switched additional doorknob caps up to 2000 pf. I got these values straight out of my collection of ARRL Handbooks...
With the power off, coupling a signal generator to the plates through a 2k resistor does show resonance at 75 or 40m depending on inductor tap. It can't tune to 20m because the minimum capacitance with four tubes in parallel and other strays is above that point.
I will take a look at the grid drive more closely. The transformer is bifilar (1:2 turns ratio) thus 1:4 impedance ratio, with the 200 ohm swamping resistor it's close to 50 ohm and the input SWR is very low too.
How much swing at the grids should I be looking for? I thought after looking at the curves for a 4-125A that 100 v p-p would be plenty. That's about 30 v RMS, or 18 watts into the 200 ohm resistor, and I've gone well above that from the SB-102 driver without getting any screen current either.
Sounds like the no (or very low) screen current is telling us something... if I remember right, it should be about 4.5 ma per tube when properly driven/loaded?
« Reply #14 on: March 24, 2010, 11:23:01 AM »
Do you have a good Bypass on each heater lead and each screen lead?
I would think 100 volts would drive the tubes well. Also look at your plate coupling cap. If it is too low a value or bad you won't couple power.
« Reply #15 on: March 24, 2010, 11:27:59 AM »
I think you have too much inductance. I would think 10 uh- 12 uh on 75 should be enough.  I think the Q is too low so the second harmonic isn't well attenuated.
I assume you are running AB not class C.
Gito
« Reply #16 on: March 24, 2010, 11:37:47 AM »
Hi Charles
A class AB1 amplifier doesn't need power to drive it,it needs voltage ,since there's no grid flowing in it.
So the driver power is dissipated  in the swamping resistor,and grid resistor of the Final tube,
You wrote that You can easily drive 100 v peak to peak the Final Rf tube but got no" output."
Maybe,just a maybe You forgot to put an RFC between the G1(control grid) and the Bias supply ,
So the Rf drive (voltage)  goes directly to G1 which is also connected to the bias supply,that works as a smoothing supply.
So the bias changed because of it ,that makes the plate current also change?  not because amply ing the Rf drive .
Gito
WB3JOK
« Reply #17 on: March 24, 2010, 12:00:22 PM »
Yes, the heaters and screens are bypassed, short leads too.
Plate coupling cap is three 680 pf Russian ceramic doorknobs (about 1" diameter) in parallel.
A class AB1 amplifier doesn't need power to drive it,it needs voltage ,since there's no grid flowing in it. So the driver power is dissipated  in the swamping resistor
Agreed, that is why I designed it that way (to drive with a low-power exciter of about 10 watts).
I wish it were that simple a problem Wink - but I did put rf chokes in each grid lead. The 100 v p-p was measured directly at the grid socket pin (with power off, though), so I know the wiring is ok.
More later when I get some time to look at it this afternoon.
« Reply #18 on: March 24, 2010, 12:15:48 PM »
What value are you using for the resonant plate load.  I am assuming you are planning on using the 4 tubes in parallel to run around 1 KW input at around 333 mils at 3 KV loaded.  If so, in AB1 I believe you are looking at around 5,500 ohms.
Unless I made a calculation error (quite possible) you are looking at 85 pf for tune less the stray plus tube capacitance, 300 pf for load, and an inductance tap at 21.  These are for the 75 meter range.
The values you are using are correct for a 2K load but you need to be running either close to 2000 watts (too much for those tubes in AB1) or greatly reduce your plate voltage to hit that value.
« Reply #19 on: March 24, 2010, 12:43:08 PM »
are you sure the loading vacuum cap is good?
WB3JOK
« Reply #20 on: March 24, 2010, 03:00:46 PM »
<snip> looking at 85 pf for tune less the stray plus tube capacitance, 300 pf for load, and an inductance tap at 21.  These are for the 75 meter range.
What tank Q did you use for those values?... I believe I need a fair bit higher than Q=10 in order to "make it work" on 40m, with the large stray + 4 tube minimum. So there will be some increased circulating losses but it's a compromise either way.
Yes... checks out on the LC meter, and the output power  tunes through a very broad maximum as the loading cap's shaft is turned.
Please excuse the crappy appearance, I have been cutting and hacking connections all over the place  Roll Eyes
« Reply #21 on: March 24, 2010, 03:27:39 PM »
That is obvious but one way to see what is going on is to try to drive it into grid current. That should be possible no matter what is on the plate side. Without a grid meter its guesswork. If the tubes arent taking drive it aint gonna work.
Either that input toroid is connected wrong or something else is keeping the drive from exceeding the bias. Try just a 50-100 Ohm non inductive resistor or even the 200 if the rig will load into it.
With only 3pf output C per tube that amp will even run on 10M once the strays are minimized.
« Reply #22 on: March 24, 2010, 04:32:59 PM »
Those are for 75 meters, the values I calculated for 40 meters are 47 pf tune, 200 pf load, 11.2 uh inductance.  This is with a Q of 12 which ought to be fine for a class AB1 amp.
« Reply #23 on: March 24, 2010, 04:34:17 PM »
I have a 4-125 Eimac spec that calls for 600 volts on the screen with -96 volts of bias and 96 volts of drive (at 2500V). So you have to drive the grid up to zero.
« Reply #24 on: March 24, 2010, 04:35:57 PM »
I would say double the C and 1/2 the L for 40M
Page created in 0.062 seconds with 18 queries.
