May 30, 2024, 08:24:25 AM *
Author Topic: magnetic deflection and scope-clocks - off the wall  (Read 29027 times)
« on: February 26, 2010, 12:27:22 AM »
How it is I do wierder and wierder experiments I don't know, but here is a decent one.
I bought a couple of O-clocks from sparkfun.com. These are oscilloscope clocks that draw vectors on the X-Y screen so that you have a dial or digital clock in various incarnations drawn on the CRT face.
The clock is repeatedly drawn in about 5.6 mS. - 178Hz.
The minimum time the ADC output is at rest is 2.25uS
The ADC output risetime is <200nS (however I did not calibrate the probes and had only the 100MHz plugin in use)
The usual electrostatic scope would display this well. I now have a special use for some old scopes I should pick up here and there.
The Wavetek 1901C X-Y electromagnetic deflection scope I have on hand is OK to 10KHz in the vertical channel. Needless to say the display was amusing gibberish.
With a 2.25uS minimum timing, that seems equivalent to a period of 4.5uS for a complete "cycle". That is about 222KHz.
Therefore, for minimal distortion, the scope must have a bandwidth of about 2MHz or better.
X-Y displays using electromagnetic deflection in my posession seem to do about 10KHz flat and 20KHz at -2dB. That is where I am going, in order to get a large size display.
What this means is that the time period where the ADC output rests at a particular value would need to be increased to 100uS to drive an existing display. Following the lengthening of the time, the display would then re-draw in 124mS, so about 8 times per second. Maybe worse if my guesses about the scope performance are off, maybe 4 times per second. These are based on measurements, but I have not done the experiment itself because the clock has to be slowed down by adding a delay to the DAC writes. The guy that designed it is willing to help out for the purpose of the experiment.
In any case, 4 or 8 Hz is too slow. The re-draw must be at least 20 Hz to prevent too annoying a flicker (exception would be the P15 or P7 phosphor).
The typical X-Y display around here runs 2-3 amps peak in the deflection coils and uses a current feedback amplifier running on +/-25 volts. There is the limting factor, the voltage. At > 10KHz, the current (and magnetic field) cannot build up fast enough to reach the necessary level and move the beam. The coil has about 1mH inductance and is otherwise unremarkable compared to other deflection coils.
The current through the inductor after a given time is dependent on the voltage across the inductor. Assuming the amplifier could handle a high bandwidth, such as 200KHz, it seems that the amplifier supply voltage (and output) could be increased and that would proportionally decrease the amount of time necessary to reach a given inductor current.
A +/-250V supply would drive that allright. 1/10 the time necessary to make 2-3A through the 1mH coil vs. the +/-25V supply.
Ten times the speed unless I am missing something.
One side of me says to get some 1000V MOSFETs from work. But we do not make very big P-channel. Only N-channel. So therefore the amp would have to be not-complimentary, and become more complicated. It has to be a DC amplifier so that it is self balancing vis the curent feedback. I have only ever done this with bipolar DC amplifiers, and never higher voltages than +/-15 to 30. i am no whiz at solid state amps.
The other side, which is more devious, says to open the case of 6CD6's (230mA average), except the yokes are not tapped.. I do not think this is the apropriate place for iron either. I had, many moons ago, a 6146-driven, 19" rackmount X-Y display. It is a great pity that is no more. I never made a schematic of it, but one pair of tubes did drive one winding of the yoke directly and the circuit was unusual having + and - voltages around 500V; I did not understand it at the time as I was maybe 13 but I think the tubes were stacked voltage-wise with the yoke from the midpoint to ground through a small resistor. The resistor provided the current feedback to steer the yoke current linearly with respect to the input voltage.
Anyone seen a schematic for a medium voltage DC coupled amp of any kind that can do about +/-200v and handle +/- 3A peak?
That could get the display to a point where the clock could drive it fast enough to avoid excessive flicker. The attachment is schematics of the of the Wells-Gardner and Amplifon monitors used in vector-draw video games like asteroids, space duel, battle zone, star wars, etc. so it is interesting to note the current feedback, etc.
* monitor.pdf (374.42 KB - downloaded 360 times.)
« Reply #1 on: March 01, 2010, 07:22:56 AM »
   Patrick,
    Your experiments may be weird, but I'd rather say their just plain cool!
So does your HV amplifier have to provide a analog output, or can it switch between the states of +200 to -200v? A big HV power op-amp might need one of those big heatsinks you just got for those microwave RF load resistors..
« Reply #2 on: March 01, 2010, 09:07:59 AM »
You know a circuit for an older radar CRT might do the trick. When I was in the USN, we installed the deflection op amps that were designed with tubes! Even with the temp. constant, they managed to work quite well.
« Reply #3 on: March 01, 2010, 09:23:02 AM »
Post a picture?
               _-_-
« Reply #4 on: March 03, 2010, 01:21:06 AM »
The amp has to make an analog signal and be DC coupled. This is because it (or rather the pair of amps) has to set a current in the yoke that will define a particular location on the CRT, and hold it there till it is time to move it again. It has to do this with precision to avoid the drawn clock face and marks from being distorted.
What I am not finding yet is the best schematics for high voltage amplifiers. I have found direct coupled tube amps of days gone by, but I don't know where to find the old tube type radar deflection amplifier circuits.
The DC coupled amp shown is called a headphone amp and is from http://www.pastisch.se/tubes/images/head-otl-1.jpg It is interesting because the top tube apparently does not have to be driven, only the lower one is.
The larger amp with the three output tubes shown here http://userpages.bright.net/~geary/misc/radiohandbook.html should be familiar to us and has been around since WWII when they used to use electrolytics for coupling. But it is not DC. The idea there is that several tubes can be put in parallel.
With either one of those, it's not clear if the output could swing very far despite the plate voltages, and further, how would such a low current thing shove 3A peak current into a load. So I would very much like to find schematics for tube-type radar op-amps.
Otherwise I am afraid I will start going through MOSFETs, which I know alot about, but not how to build large amps with. The third alternative is to take one of the wells-gardner designs and replace all the transistors with high voltage types and stack them for more as was done in the Tigersaurus 250
(http://www.swtpc.com/mholley/RadioElectronics/Dec1973/RE_Dec_1973_pg44.jpg) - but when one transistor goes in something like that, they all like to go! - and I have destroyed solid state amps carelessly driving deflection coils back inthe 70's and 80's.
W3SLK - do you recall what kind of resistance and inductance the radar deflection coils had? Any chance I can find a schematic? Lots of guys have stashed stuff like that in their garages over the decades.
Bear - I will get some pics of the lash-up. and various displays showing how they behave.
It's a mess right now as the H/P 1300 display that Wavetek 1901C and notebook computer is sitting on caught fire, or tried to; the smoke came out anyway. I need to get another one off the shelf. It fried right away before I could even get the beam up. I have no book for it. The 1300 is a electrostatic 13" rackmount display that was used for old computers among other things. Anyone know?
and speaking of the notebook, I am trying unsuccessfully to load the experimental firmware to the O-clock, so that has not worked yet. some kind of acknowledgement error in the transfer.
« Reply #5 on: March 03, 2010, 09:13:02 AM »
Patrick asked:
I'm sure the information is de-classified, (it was Confidential when I was working on it). You seem to have access to some of the military stuff. These were the PPI's built by Hughes Aircraft. They were part of the AN/SYA-4 display system which I think was built back in the mid 60's. If I find anything, I'll pass it on.
« Reply #6 on: March 03, 2010, 09:40:28 PM »
I guess what I am getting at, no one has yet bothered to scan the old stuff like that, or much to advertise copies for sale. It's no longer (if ever was) avail from the gummint sites. I spent 2 years looking for the URT-12 transmitter manual. There is a yahoo group I might try "military radars" and the GB group.
John K5PRO
« Reply #7 on: March 04, 2010, 04:37:08 PM »
Patrick
Apex Precision, now a part of Cirrus Logic, may have what you need for 200 volt op amps with a few amps. Take a look:
http://www.cirrus.com/en/products/apex/matrix_linear.html
Also check with Supertex.
When are you gonna come over to NM for the big capacitor? I think its still sitting at Jim's house, he'd sell you the house to go along with the capacitor if you want.
John
« Reply #8 on: March 05, 2010, 01:29:08 AM »
If they would ever let me save up enough vacation.. Soon, it is only a days drive or so. I need to wait till it's warm enoough to go to IL again too. Right now I am in the hole for a big diesel truck repair.. >$2000.
« Reply #9 on: March 05, 2010, 09:12:20 AM »
Tigersaurus - avoid. Unstable, lets the smoke out - not for DC offsets.
Tubes, sure... as long as the current is fairly low the voltages can get high.
Sweep tubes?
How many volts do you need for deflection?
High voltage Mosfets are nice. Easy enough to use.
Most CRT monitors have them...
I still don't quite "grok" the project??
You say "firmware", but then you say "oscope"...
Has anyone else done this - are there commercial offerings of this sort of beast?
Ed/KB1HYS
« Reply #10 on: March 05, 2010, 02:00:10 PM »
screen shot from the site with the clock. Also has a serial Terminal mode for your Oscope (same device) Monocrome green is back!
73 de Ed/KB1HYS
« Reply #11 on: March 05, 2010, 07:41:10 PM »
Yeah, I don't think there is quite the demand for those PPI's in the private sector. The voltages were substanial and amplifiers small. They used the tubes where just the wires came out their base. I would bet that 15~20 years ago I could probably recite that circuit from memory having overhauled many on our test set. But too many tides and too many women, (ok just too many tides) have been cast asea since I last messed with one.
« Reply #12 on: March 05, 2010, 08:49:12 PM »
yeah, looks like high peak voltages and currents, lower average power that that suggests. Maybe some safe operating area concerns.
« Reply #13 on: March 05, 2010, 09:23:28 PM »
The one pic shows the XY mode with the clock displayed on the left and one timebase running against the  H scopeclock output to give an idea of the general waveforms.
I did not know the Tigersaurus design was unstable. Thought it would be OK for a DC job. The IC's pointed out earlier - -yeah OK, but they are $350 to $700 for the kind I would have to use.
The reason I think of tubes is that the old XY instrument I had before had two 6146's per axis and was DC coupled. Winding DCR was about 20 ohms, no idea what the yoke was like other than that. There are plenty of much more current-able tubes like the 6CD6 and even the 6080 and 6883.
The amplifier of an electromagnetic deflection display is a current amplifier. The output current is linear to the input voltage. The voltage output is whatever the current feedback resistor says it needs to be. The resistor is placed in the return of the yoke and 1 ohm non-inductive is a good value. The current demanded by an electromagnetic display is fairly normal to the image drawn.
The waveform needs to be studied to see exactly what the real duty cycle would be, before an amp can be envisioned. I was looking at the Tigersaurus as a model of overkill but have not decided on an amplifier topology yet. This waveform studying has to be done on an electromagnetic display capable of drawing the image, even if it is a very small drawing due to amplifier voltage limitations. The Wavetek's amp has an on-purpose roll off around 10-20KHz. If it were good to 100KHz, and stable, and the scopeclock's drawing speed slowed down enough to make 100KHz a reality, then the it could be studied using the wavetek.
I am calculating +/-200 to 250V peak for deflection using salvaged commercial and military XY display yokes. The important thing will be the current, up to 3A on peaks. The voltage is only necessary to get the current up to the proper level quickly. A means of overcoming the inductive reactance. The way I have arived at this value is straight off the inductive reactance tables. 10X the frequency, means 10X the voltage, for the same current increase per time unit.
The firmware I mentioned is running in the scopeclock board. It has a small monitor program that lets you configure the clock (interrupt by a switch on the board), and then it looks in a table of data for the selected elements to draw, and draws them one after another by writing values to a DAC. The computer chip doing this work is an Atmega AVR 328 (I think). There is an RTC to keep time and it can be synchronized with an external standard. So that is why I have mentioned the firmware. I am trying to load a special version that provides a user-programmable delay after each DAC write. (programmed from the serial port to a PC with a terminal program if i understand right) but the PC connection is giving an error apparently becoming unsynchronized with the scopeclock board.
This weekend, I have to work on the webserver that runs magnetosphere.net & radartruck.com, and also runs those for antiqueengineer.com and cjwatersenterprises before those guys notice their websites have disappeared. Then I have to exchange a transistor tester that was broken for one that is not, with a guy in fort worth. So I might not get to play the weekend with this project, maybe. I have to at least try to successfully load the experimental firmware the dutchtronix guy provided, as he has gone far out of his way to help me "slow the clock-drawing down" enough to do meaningful electromagnetic deflection experiments.
« Reply #14 on: March 06, 2010, 10:01:33 PM »
I'm not 110% certain on this, but I think ur in the market for some old school B&W TVs and tubes!!
 Grin Grin Grin
That and some color stroke vector "video games"... although maybe you have to repair them and not gut them...
« Reply #15 on: March 06, 2010, 10:18:59 PM »
That is right.. the old school monochrome sets! and if I can find them cheap-o, the vector scan monitors from the video games would make a great test device. I have one, a wells-gardner from Space Duel. 19" color CRT busted, but it is a Hitachi CRT almost exactly like a 25" Hitachi CRT sitting in an RCA tabletop cabinet here. Those are buried in the garage at this time though. I would try and repair those kind of displays for sure.
I asked around for schematics and was directed to
http://cer.ucsd.edu/~james/notes/MIT%20OpenCourseWare/MIT%20Radiation%20Lab/
specifically PREF22.PDF and V22.PDF
The above link seems to contain all? the "MIT radiation lab" books scanned. 8-)
anyway, I had forgotten that my friends were coming over today to help start the antenna tower project. We drilled six 10" diameter 5 FT deep holes, and also a cluster of four of them in the middle of the yard for the tower foundation. Isn't that great news?
So no firmware fiddling, returning transistor testers, or anything else today.
« Reply #16 on: March 07, 2010, 01:43:33 PM »
Patrick,
drilled holes?
do you mean a post auger??
I am looking for ideas on how to drill ~1-2" holes into shale... 6-8 feet deep...
« Reply #17 on: March 07, 2010, 09:19:37 PM »
Must be a post auger. It has a vertical shaft 1-cylinder engine with 4 long operator handles and a big screw drill about 4 FT long and 10" diameter underneath. I don't have anything to drill 1-2" holes in shale, we were definitely not doing that kind of drilling.
Today it rained and got real messy. The dirt is clay and that caused isues becoming like instant peanut butter muck. It became impossible to use the auger to drill further and so we will have to finish the job in 2-3 weeks when the guys are available again. I put a cover over each hole to keep dirt and rain out. What diging remains is the tower foundation hole. It's about half done.
The backup disk on the bunker of doom server also failed today. I think that spindle itself is some 4+ years old. The server is running OK but when it rains it pours. Time to fix computers.
OAS, I read volume 22. I also downloaded all 28 volumes & backed to DVD. From the info, I patched the attached diagram together. The deflection coils have no center tap, but it is just for thinking about at this time and there are ways around that if necessary. I am not concerned with efficiency in the deflection amplifiers. Just want to get things on track. The mosfet modulators for the class E rigs recently discussed are looking interesting too.
« Reply #18 on: March 19, 2010, 11:24:23 PM »
This weekend, no military service, nothing to do but try several computers and see if any serial ports among them will load firmware to the great and wise scopeclock's RS232 port. I'll post up what is done, and I promise pictures if the software loads.
The holes for the antenna system still remain a bit unfinished. Maybe next weekend. Each was covered so as not to fill back up.
« Reply #19 on: March 21, 2010, 05:08:18 PM »
The software was successfully loaded. The problem loading it before was noise on the power supply. The supply was nice and quiet but soimething went wrong there. i used a different one.
This is the result when the image is drawn 8 times per second. It is too slow for use on a high speed scope due to flicker, and the display is still showing it's slowness. A long persistence phosphor like a P7 would be best at such a low rate.
The risetimes of the scopeclock signals here are about 50us. That is reasonable considering the deflection can be sped up by using a better amplifier. I am trying to get the videos together and will advise when posted. The unblanked lines are a result iof the display lagging.
« Reply #20 on: March 21, 2010, 09:10:43 PM »
the 8-minute video about this is here:
http://www.youtube.com/watch?v=yat2eeKZ8iM
« Reply #21 on: March 25, 2010, 03:41:05 AM »
A new alpha of the software was loaded. The DAC remains at each state for up to 150uS, a far cry from the original approx. 3uS. The delay is implemented by a counter that decrements to zero from a user defined value of up to 999 (decimal). The DAC output slew rate from one voltage to the next of course is not affected but since the associated time is as small as 0.25us (measured, possibly stretched, at the scope), the cabling will require due attention.
The writing "speed" is therefore adjustable in 6.67us steps, and the time per object (a dot), determined by the timing between writes, is approximately 3.25+(n*6.667)us.
The overall refresh rate depends on the number of dots, so that the clock menu options, giving everything from a fancy chronometer face to a binary set of large dots, determines how much time is spent to redraw the entire image. This does not affect the magnetic deflection requirements but is only an overall time for the drawing of the sum of all the DAC steps required.
At 150us per sample, the Wavetek did a very acceptable job of drawing the clock face. This is roughly equivalent to a 6.67KHz frequency. I did not count how many times the clock was drawn per second, but it seems to be between 6 and 8 per second.
A minimum of 30 to 60 drawings per second is necessary for the eye to perceive a good image because we cannot rely on a CRT having a long phosphorescence time in all cases; not everyone will have a P7 or similar phosphor. In fact I have a few P15 types with a 3us persistence. P4 as used in monochrome TV sets has an exponential decay to about 7% after about 33ms, but we know that the 60Hz vetical rate of television is only 16.7ms and the phosphor must maintain some brightness for enough of that time for the eye to do the rest.
The goal is to create a design that will be flexible for other hobbyists to reproduce. The necessary bandwidth of the deflection system is therefore close to, but no more than, about 1KHz/(refresh per second). This is aligned closely with the original estimate of 50-60KHz in case of a ~60Hz rate. I don't know how difficult, or possible, it will be with existing yokes including some designed specially for precision XY use but I intend to find out. This will take some time!
The next issue is to deal with the blanking amplitude and polarity. This is a minor hardware issue. The scopeclock from Dutchtronix/Sparkfun has a blanking output with a swing from 0 to Vcc, appx. 3.3V or 5V. There is an onboard inverter so that the blanking can be + or - polarity. When the clock runs at the stock speed, it is easy to see that the blanking can be AC coupled to the Z axis input of an oscilloscope to provide the desired effect. This is the wrong way to do it because the DC reference is lost and the overall amplitude above and below ground will change with the average blanking duty cycle, and that does change from mode tio mode. Many scopes of higher quality have a DC coupled Z input and therefore may require a positive or negative DC voltage to control the intensity. The Wavetek is one of these. After fiddling with the blanking at low speeds, I found that the blanking requires a signal that is negative with respect to ground. This is not available on the board and will have to be obtained via an amplifier using a bipolar or negative power supply. The blanking is essentially binary and looks like a simple TTL signal.
A secondary blanking issue will be seen next because the display's deflection system will always have a finite rise time due to the yoke inductance. (With an electrostatic CRT on a 1-2MHz scope it is a non-issue.) The beam therefore may still be moving into its precise place when the unblanking occurs.  A one shot with a variable delay placed between the clock board and the negative polarity blanking amplifier should help to overcome this issue by lengthening the blanking pulse by a few microseconds so that the beam position is settled before it is unblanked.
At this time I have to apologize for the lack of AM information in this topic. I really have gotten off the topic of the BBS. Perhaps an application would be a GPS-accurized 24 hour station clock and transmission time indicator that can be set by RS-232 commands. Old Buzzards can talk for a very long time.
« Reply #22 on: March 26, 2010, 04:06:24 PM »
Welllll, it is kinda technical and interesting use of an O'Scope
Phred
« Reply #23 on: April 03, 2010, 08:07:53 PM »
Here is a pic of what it does at 150ns per DAC write as described above.
It can be seen there is a difference in performance between the H and V channels of this display. It is noticeable at the 21-24 and 54-56 marks for example.
The issue is the H deflection amp does not have as fast a slew rate as the V amp. Inside the instrument, they are not the same design at all. There is a 10 second video of the clock running on youtube: http://www.youtube.com/watch?v=39cUFDhAZ5Q
Ok, well it is time to build a deflection amp. That is the real challenge and I'll probaly have to try a couple or more times to get it right.
« Reply #24 on: April 03, 2010, 10:48:16 PM »
Still quite the feat. I wish I had your ambition.
