Does anyone have a schematic for a relatively simple, but effective 700vdc regulated supply? I'll need to pull ~250ma.
Ray, Do you want tubes or solid state?
Questions:
1.) line voltage regulation?
2.) Load current regulation?
3.) Ripple reduction?
4.) How much voltage drop can you accommodate if the regulator is a linear series pass type?
5.) What is the Peak to Peak ripple amplitude on the raw supply at 250 ma load, and how low is the dip in the ripple when the AC line is at minimum, say 110 vac?
6.) Does the supply need to survive a short circuit?
7.) Just curious, what is the application?
