June 07, 2024, 11:03:56 PM *
Author Topic: Anyone know of any small (around 2 inch) 15 A DC panel meters?  (Read 5561 times)
« on: January 03, 2010, 12:07:15 PM »
I'm having a heck of a time finding some small 15A dc meters.  They need to be less than 2.5 inches wide.  I've checked a lot of places.. I can find larger meters, but no small ones.  Any ideas?  I would prefer round, but I don't think I'm going to get that.  I need 12 of them, although only 6 right away.
Let me know  Wink
« Reply #1 on: January 03, 2010, 01:02:47 PM »
Based on the earlier thread I started... I won't recommend Shurite  Smiley... although they do sell an inexpensive 0-5A 2.5" meter
http://www.primetechnology.com/PartsDetails.aspx?PartsId=77&Parentid=28&ParentType=C
If you can find a meter you like with a much lower range (e.g. 0-5 mA) then what I might suggest is the following:
Put a resistor in series with the meter to bring the total series resistance (meter + added resistor) up to 100 ohms [.005 A x 100 ohms = 0.5 volt]. Then, you can use a 0.1 ohm shunt.
Best regards
« Reply #2 on: January 03, 2010, 01:04:11 PM »
does the meter face have to be less than 2.5inches or can the cut out be less than that?  All Electronics has square meters with a cut out that is about 2.25inches round with a square meter face about 3 inches wide.
http://www.allelectronics.com/make-a-store/category/385/Meters-Panel-/1.html
Jim KF2SY
« Reply #3 on: January 03, 2010, 01:06:17 PM »
you could also go the digital panel meter route.
Much smaller cutout.
http://www.newark.com/jsp/search/browse.jsp?N=0&Ntk=gensearch_001&Ntt=categorynumber83946
http://www.datel.com/data/meters/dca20pc.pdf
N4LTA
« Reply #4 on: January 03, 2010, 01:20:47 PM »
If you are willing to pay $55 for one - go to the Meter Center. They have new Yokagawa meters which are the old GE line and are still made in Georgia.
They will scale them for you and have shunt rated ones. I use them all the time and they are very good meters. they have 1 1/2 " to 4 1/2"
Do a Google on Meter Center. They usually drop ship from the Georgia factory.
Pat
N4LTA
« Reply #5 on: January 03, 2010, 08:41:07 PM »
Hi ! Thanks for the replies so far.  I'd like the meter faces to be around 2 to 2.25 inches if possible.
I may not be able to find what I'm looking for, in which case I'll have to modify the physical layout of the meters and use two rows or something like that - no big deal, really.  Just thought it would be nice to keep them in one row  Smiley
The 15 ampere meters from All Electronics look good, but they are closer to 3.5 inches.  I'm still looking, but soon the project will be in need of meters, and I'll have to use what is available   Cool
Thanks and Regards,
Jim KF2SY
« Reply #6 on: January 04, 2010, 08:56:58 AM »
Maybe these will fit the bill:
http://www.newark.com/jewell-modutec/oms-daa-020-u/current-meter/dp/44F4763?Ntt=44f4763
or maybe these:
http://www.alliedelec.com/search/productdetail.aspx?SKU=3780048
KD3CN
« Reply #7 on: January 04, 2010, 01:55:14 PM »
Here's one for $13.25 ea.   Front panel dimensions 23/8" (H) x 13/8" (W).
http://www.mcmelectronics.com/product/TENMA-PM-2-15A-/PM11279
Hmmmm, twelve 15amp current meters.....  I like the sound of this!   Grin
73, Karl
« Reply #8 on: January 05, 2010, 09:43:44 AM »
73, Karl
Wow, I think that might do the job very nicely !    Thanks for the info - good find  Cheesy
Page created in 0.037 seconds with 18 queries.
