December 01, 2025, 04:31:04 PM *
Author Topic: Solid State Class C Collector Modulation  (Read 22144 times)
« on: November 11, 2009, 04:20:47 PM »
Is there such a thing as collector modulation for solid state? Assuming the high level topologies are similar with the difference being the devices (hollow vs. solid state), how come I never see collector modulation, class C operation for instance when searching for a solid state version of a class C solid state AM transmitter even for low power apps?  I would think that since the topologies are similar there would be many circuits.
Home of GORT.
« Reply #1 on: November 11, 2009, 04:59:31 PM »
Like a cb set?
that is what they all do...
Brett
« Reply #2 on: November 11, 2009, 05:12:59 PM »
I've been spending LOTS of time lately serching for just that!
CB's... Well, aren't they mostly low-level modulated?
I guess the old one's weren't (AM only)... because they had a choke and mod-tranny.
these days they are mostly SSB, with AM, FM added on.
I have been trying to find a circuit that doesn't use a modulation transformer...
Just straight series modulated.
So far only basic outlines, nothing that is "tried-and-true".
« Reply #3 on: November 11, 2009, 05:13:44 PM »
Like a cb set?
Brett
Yeah, I guess like a CB set but on a larger scale like 50watts or more. Is there a design restriction that these are not as prevalent as other topologies?
Home of GORT.
« Reply #4 on: November 11, 2009, 05:22:29 PM »
Its just like cb sets, and they make  high power ones now disguised as 10 meter rigs, I had one, did 30 watts and had a collector modulator in it, along with the ssb and fm stuff.
I cant say if they are all made that way these days, but i think most are.
Its just a matter of scale, bigger and/or more RF output devices, bigger heat sinks, bigger modulators...
Its real easy to do 4 watts outand modulate it with 3 watts, you can get 20 watts of audio out of a small 5 pin to220 package these days..
Two in push pull would do 40 watts and modulate an 80 watt input final.
They take almost microphone level input...
Brett
« Reply #5 on: November 11, 2009, 05:31:49 PM »
Yeah, but that still means using a modulation transformer...
I haven't used one in a rig yet, and don't want to start now!   Wink
But, want to try Class C at 10 meters, and just use a series modulator/power supply, but of course would use mosfets.
That's what I'm looking for anyhow...
Sometimes just to lazy (or pressed for play time) to do some trial and error.
« Reply #6 on: November 11, 2009, 05:38:59 PM »
Well, if you dont mind the hit in efficiency, you could just do a solid state version of a cathode modulated rig with a pass tube / pass fet...
« Reply #7 on: November 11, 2009, 06:18:09 PM »
Get the schematic for almost any CB from the mid/late 70's one. Every one I've looked at was series mod with no mod tranny.
« Reply #8 on: November 11, 2009, 06:22:50 PM »
Yes, the "Pass FET"... is what I'm getting at, was thinking "series modulated" was the same thing, though possibly wrong terminology.
But, not being an engineer... I need schematics, at LEAST as a good starting point...
I just hate to waste hard to come by time by trying to figure out what has already been figured!
« Reply #9 on: November 11, 2009, 06:26:39 PM »
Huh,
I'll have to look harder!
The ones I found all do have the mod transf...
But those were all basically the same, infamous, board, that used the PLL IC (PLL-02A ?) configuration, that made them a breeze to put on 10m.
Hmm...  back to Google!
« Reply #10 on: November 11, 2009, 06:49:20 PM »
H mode modulator will be more efficient but any FET or transistor biased at a bit unter 1/2 power supply voltage will work fine as long as the heat sink is big enough to dissipate the heat.
There is no need to negative bias the final just bias to zero which is below cut off.
Just a class e without a shunt cap. A low pass filter on the output is all you need.
Jay W1VD has added a parallel tuned circuit between both sides of the drains of a push pull to clean up the waveform. He is getting very good efficiency without any tuning required
« Reply #11 on: November 11, 2009, 06:56:47 PM »
Frank,
I had played with Jay's Class-D designs a bit, at low power (5 watt carrier, pair of IRL510's).
Question is... can that Class-D design be made to play friendly at 29mhz?
« Reply #12 on: November 11, 2009, 07:11:54 PM »
Why not. IRF510s will work on 6 meters.
« Reply #13 on: November 11, 2009, 07:24:48 PM »
In Class-D ?
« Reply #14 on: November 11, 2009, 10:02:31 PM »
You can AM modulate the voltage on the drain of an RF Power Mosfet.
See page 5 of 6 which is the app. note for a Class C circuit.
http://www.ixysrf.com/pdf/switch_mode/de275_102n06a.pdf
« Reply #15 on: November 11, 2009, 11:54:09 PM »
Search Series Class A modulator.
I've designed a series modulator that I did well marketing to the HiFi CB crowd.  Remove the final and driver Vcc, and insert my modulator Vcc at that point.  Line level into the board, and you have modulation control, carrier control and supermodulation / ultramodulation controls as well.  I also did one that had negative peak clipping on it, but didn't like the overall effect.
There is a BIG market to the channel 6 guys with this now, I finally threw in the towel after my wreck and gave it pretty much to my competitor, MotorMouth.
But take a look at any CB rig for ideas.  The SSB radios used collector series modulators, the 138/139, 142/146/148/2000/grant/washington bases did as well.
ALL the Galaxy offshore crap is now series modulated, and you can also take a look at their schematics and learn the different voltages needed to get it to work high level modulated Class C, as well as when they rebias it for SSB.
The reason people don't use series modulators is they are inefficient.  BUT, as simple as a TIP31 to modulate to 25 watts PEP driven from a simple audio amp, nothing to sneeze at.
My series modulator, outboard, has a total parts count of 12 devices.  All ordered through Mouser.  20 bucks a board to build, > 100 out the door + shipping Smiley
I've even played with doing it at the amplifier level, and breadboarded one up to the 600 watt (PEP) level, using a quad of 2879s.  SUPPOSEDLY, after showing this off at a couple breaks, another Channel 6 guy came up and said I stole my design from Dentron, as they had something in the wings.
Truth be known, I copied and improved upon the textbook one from Lou Franklin's Understanding and Repairing CB Radios.  I BELIEVE you can find that online with google books or something else.  VERY simple schematic.
Next year the person I gave up the competition to should be marketing a modulator that has line level inputs, and can hook up to a 16 device amplifier, equating to nearly 2.5 kw PEP output, AM... High Level.
« Reply #16 on: November 11, 2009, 11:57:10 PM »
Huh,
Do NOT confuse a modulation transformer with a hash filter.  I've had that argument with more than one person.... Like, the Cobra 148 has a BETTER modulation transformer from the phillipines, or the one with the yellow sticker on top.
TRUTH BE KNOWN, NOT A SINGLE SSB RADIO UNIDEN / COBRA MANUFACTURED SINCE 1982 HAS HAD A MODULATION TRANSFORMER IN IT!!!!!!!!!!!!!
So, head over to CB Tricks, and check out the Galaxy radios section.  Pull up one of the dual final radios, and copy the mud-u-lator out of it.
They are good for 40 watts PEP out of the box, and if you change the pass transistor, I've used that circuit to 100 PEP.
« Reply #17 on: November 12, 2009, 12:47:08 AM »
Ok Shane,
No no mistaken the transformers I am refering to are audio transformers...
The primaries driven by either an audio amp IC, or a push-pull pair of npn's...., one secondary to the speaker/PA speaker, and the other secondary has V+ on one side, and the other side to the collector of the RF PA collector...
« Reply #18 on: November 12, 2009, 01:07:02 AM »
Well sure .... that's how my Class-E, and Class-D rigs operate...
I've just never built a Class-C  amp before!  Grin
Ian VK3KRI
« Reply #19 on: November 12, 2009, 05:58:15 AM »
I have an aircraft band (110Mhz) AM transmitter here that uses a 28V VHF power transistor run at 12 volts with a push pull audio stage and conventional modulation transformer . Just replace your Class B modulator tubes and class C tube with NPN transistors and you've got the circuit .
        Ian VK3KRI
N4LTA
« Reply #20 on: November 12, 2009, 09:00:50 AM »
To get 100% modulation, you generally have to modulate the driver stages also.
A 10 watt output 25 volt IRF510 transmitter has a collector current of approx .6 amps which gives a drain impedance of about 42 ohms.
If you have a small solid state amp of 15  watts or so you need a modulation transformer with a turns ratio of 3.25:1
a 120 volt to 36 volt filament transformer might work if it is fairly large so it won't saturate. The old ARRL Handbooks had SS modulators that used filament transformers to modulate tube stages. Anything close should work as most SS amps can match most load impedances from 2-16 or so as they are current source type amps.
The power output generally drops as the load impedance rises.
You could also use a small  PWM modulator.
Pat
N4LTA
« Reply #21 on: November 12, 2009, 11:41:14 AM »
Class  E like class D does not need to modulate the driver. If you have enough voltage swing on the gate. There is no advantage of driving the gate past saturation and the reverse transfer C is low providing isolation at negative peak. Reducing gate drive with modulation will hurt efficiency
« Reply #22 on: November 12, 2009, 10:08:37 PM »
modulate the 12V leenyar. Most can be made to work OK on the ham bands. If you do that be sure it is properly biased for AB. Most today are not biased at all. The new ARRL handbook has a very nice SS linear design.
« Reply #23 on: November 13, 2009, 02:42:30 PM »
so if one were to build a class C AM transmitter using a solid state BJT or FET or more plus a  transformer for modulating the B+ at a 50w or so level could it be done ?
Home of GORT.
« Reply #24 on: November 13, 2009, 03:01:08 PM »
Yup, that's what it looks like.....
Me, I don't want any steenkin' transformers  :-)
Page created in 0.057 seconds with 14 queries.
