May 09, 2024, 11:17:58 PM *
Author Topic: Specs on Stancor Plate transformer  (Read 3521 times)
W8ACR
254W
« on: August 27, 2009, 12:39:12 AM »
Wondering if someone out there can tell me the secondary current rating of a Stancor 52B046 plate transformer. The secondary voltage is marked near the terminals (2000VCT and 2500VCT) but there is no current rating. This is a pretty hefty transformer, it weighs at least 60lb. My guess would be 400-500mA. I can't find any info on the internet. Hopefully someone can find it listed in an old catalog.
Many thanks,
Ron W8ACR
KE6DF
« Reply #1 on: August 27, 2009, 01:51:12 AM »
I doubt you are going to find that transformer in the standard catalogs.
It sounds like an BC-610 transformer as they had approximately those ratings and weighed about 100 lbs.
Perhaps posting a picture of it would help.
WZ1M
« Reply #2 on: August 27, 2009, 04:59:40 AM »
52B046 is a Hallicrafters part number.
Gary
« Reply #3 on: August 27, 2009, 11:41:31 AM »
Yup sounds like a BC610. You need a stiff 120 VAC line to feed it. It will run a 500 watt am rig. I used one for a 4-1000A linear for years then found a second one and hung them either side of a 240VAC line for better voltage regulation. Cap input filter you can get just over 3KV under load.
« Reply #4 on: August 27, 2009, 12:11:41 PM »
yep BC 610 transformer. I got a few chokes out of one and  couple of transformers/chokes  for screen supplies and exciter stages.
KC4VWU
« Reply #5 on: August 27, 2009, 07:37:56 PM »
Hi Ron,
         Go back about 5 pages to a previous post I made about a Stancor transformer and look at the pictures I posted.
Phil
W8ACR
254W
« Reply #6 on: August 27, 2009, 11:49:35 PM »
Thanks to all who replied. Yes Phil, your pictures show the exact transformer that I have. I am quite familiar with the BC-610, so now I know what this transformer can do. I have two NOS HK-254's. Should be a good power plant for those. probably could run the modulator from the same supply - mebbe 35T's or 811's.
73, Ron
