May 19, 2024, 03:34:13 PM *
Author Topic: EI core laminations help!  (Read 3883 times)
capt.m
« on: August 16, 2009, 09:03:18 PM »
help! where to to find EI Core lamination Standard dimension for a given VA rating, Table or data specs.
thank!
« Reply #1 on: August 17, 2009, 10:10:01 AM »
I don't have such a thing handy, but it does depend on the material the lams are made of... I'd look online... and in the Radiotron Designer's handbook there are references as well as charts and equations... you can download it free from Pete Millet's site, iirc... if you don't have one.
That's a start.
               _-_-
You can also look at various xfmr mfrs sites, and also look at what size cores that they use for what VA their  CCS or ICAS rated xfmrs are... they will spec the core window at least... maybe more.
« Reply #2 on: August 17, 2009, 09:23:46 PM »
Check the older handbooks. '70s, 80s there is a graph VA vs core area
capt.m
« Reply #3 on: August 18, 2009, 01:57:40 AM »
oh,
thank you very much.. Smiley
Ian VK3KRI
« Reply #4 on: August 18, 2009, 05:36:04 AM »
I plotted this from a metrified the eqn. in Reference data for radio engineers 2nd Ed (1946) :
core area(sq in) = sqrt(60/f)*sqrt(wattage)/5.58
may be of some use..
                                           Ian VK3KRI
capt.m
« Reply #5 on: August 18, 2009, 08:44:28 AM »
Ian
I  think this is wha I am looking for...
where I can download a file?
thanks...
« Reply #6 on: August 18, 2009, 01:06:12 PM »
Lamination material changed over the years. Id say the first change took place around 1959-60 and another in the 80's. If reusing ancient laminations the core requirements will be larger for a particular kva rating.
One of the old transformer catalogs had full design info using the vintage ratings but I dont remember which. Kenyon, UTC, Thordason??
Page created in 0.032 seconds with 17 queries.
