December 02, 2025, 07:17:04 PM *
Author Topic: Looking for Temp comp caps  (Read 4221 times)
AB3FL
« on: May 01, 2009, 03:14:58 PM »
I may be searching for unobtanium, but I will try anyway.  I have decided to do the K6AD temp comp mods to my MoHack.......Where can I get them from?  or does anyone haver a stock of them.....None of the big houses(jameco, mouser, newark, etc) seem to have them
Tom - AB3FL
« Reply #1 on: May 01, 2009, 03:37:00 PM »
The only place I have seen that stocks them is Surplus Sales of Nebraska.  What values do you need?
AB3FL
« Reply #2 on: May 01, 2009, 03:40:52 PM »
thanks Jim.   Surplus Sales does have a lot.
Tom - AB3FL
K6IC
« Reply #3 on: May 01, 2009, 03:50:00 PM »
But Tom,
WHAT values,  and what tempco do you need ?? ??     ?                      ?
73  Vic
AB3FL
« Reply #4 on: May 01, 2009, 03:52:22 PM »
Here is the list
These need to be NPO 128,102,214,162,186,220,80,36 all pf
110-N150, 7-N750, 11-N470, 56-N330, 47-N330, 3.3-N750, 39-N220, 47-N80, 36-N220 all pf
50-N3400 and 20-N2400
Tom - AB3FL
K6IC
« Reply #5 on: May 01, 2009, 04:54:13 PM »
Hi Tom,
Boy,   that is quite a list !    The NPO's are in current production,  but you might have to hand select to those precise values.
Think that many of those "N"'s  were someone's custom part back in the day.  In the next week,  will look @ my Disc Cap collection to see which of the N values that I have ... probably not many,  but will check  (they are in another location).      Good Luck      73       Vic
« Reply #6 on: May 01, 2009, 07:23:37 PM »
Wow what a selection of the negative values.  Like Vic said, you may have to parallel to get the NPO selections.  I do hope you have an accurate cap checker.  I took a look and can't help you with the TC caps.  I have some but not the ones you need.
Good luck finding them.
K6IC
« Reply #7 on: May 04, 2009, 11:47:51 AM »
Hi Tom,
Well,  I  did look for your N values in my collection of Discs,  and was surprised that there were NO hits ...  not even close ones.   There are a few more-or-less standard N rates,  like N750,  N470, N330, N2200,  N3300  etc,  but some of the ones on UR list,  I never even heard of before.
Perhaps in the day,  larger mfgs  would spec a custom rate for the exact situation in their TV set or other RX/TX.   There may be some triiage that you can perform to get the most bang for your effort -- ie there must be a number of circuits which K6AD is trying to compensate,  and some probably have a larger effect  on temp stability performance than others .
The NPOs are currently manufactured,  so you could perhaps select your exact values from a large paoulation of parts,  or make them from combos of parts.
73  GOOD LUCK !!  Sri could not help.      Vic
Page created in 0.045 seconds with 17 queries.
