May 05, 2024, 03:02:53 AM *
Author Topic: rEFORM sCHOOL  (Read 12571 times)
« on: April 05, 2009, 06:26:19 PM »
Today, the power supply for the Texas Grinder or Sideband Squisher or anyway the 3CX3000 amp that followed me home, it got checked out and repaired. As wisely warned by the previous orner, the electrolytics in the PSU might need to be reformed since it has been sitting for a decade or more. So my apprentice helped me put it on the work bench (this is the example for Burt of the power supply size to be used for an AM linear http://amfone.net/Amforum/index.php?action=post;board=28.0), and I go to use the 20A variac. No output from the variac. This is very annoying, so I remove the rack panel to check it out. It is going to need some more detailed repairs. It turns out there are 2 sets of brushes, One is in the coil, and the other set is two small round contacts near the hub of the wiper plate that press by springs against a metal disk attached to a bar that then goes to the output terminal. The ones in the hub were not making good contact.
Well now this is all taken apart, and I says to my apprentice, here take this away, and I can fix it later.  So then we go looking for another big variac. The ones I spotted were the 120/240V 56A ones. So ok that will do, we get one and lug the 100 LB thing to a cart and set it there, a PITA to move it, but there it is now and there it will stay, and I am hooking up a power cord to it. It has a large handwheel so that is an improvement.
Anyway this done, I jack the output to the transformer primary on the PSU and start cranking it up, and get to 2400VDC with the variac at 100%, reforming he caps as I go..  All is well. So, need 240V to apply the full alternation to the thing and reform the caps all the way. So we go hunting this 120/240/480@1KVA "control transformer" that I know is somewhere in the lab.  In doing so, I happen to notice a dual 15A variac I had passed right by and somehow missed before. Now remarking, well we could have used this one, it's alot lighter. Wise apprentice says; 'well, you won't be able to blow up the big one as easy'. Ok. he is right on that account.
So we found the control transformer and set it on the workbench, and got out the big clip leads and hooked it up. Nice. Start cranking the variac, watching the clamp on ammeter, AC voltmeter on the variac, and the HV DC meter with its HV probe and the clipleads and all on the work bench, telling the apprentice don't stand too close to that, and don't stand on the side where the caps are in case one decides to blow up . So we get to 4800V, and the variac is still not at 100%, but more like 60%. So. Hmm. Ok, what is the rating of the electrolytic stack? because this is getting weird. It's a pile of 800uF 450V caps. I am getting nervous about increasing the variac any more. (apprentice cheats and uses cellphone to multiply 450VDC*14) - so 6300V is the limit.
So, I am slowly spinning the handwheel, but on the other hand something is not right, in the back of my head I know that thing is not supposed to be putting out 5500V at 70% of 240VAC. Ok, well I did take it to 5900v, but I stop, because something is just not right, and the variac is not at 100%. The transformer in the PSU is humming only slightly. Nobody is smoking or getting hot, but I shut this down anyway, and after looking at the control transformer, I saw that it had been jumpered for 480V instead of 240V. Duh.
So at least the caps got reformed properly. Rewired the control transformer for the correct 240V and let the supply sit at 4800V for a while. That is alot of volts and I am sure it will be more like 4200 with a load. The bleed was the stack of equalizing resistors, a total of 350K Ohms (13mA). The caps are pretty good, not leaking. It took a long time to bleed that voltage off the 57uF stack. So next we will get to work on the amplifier itself.
I mention my apprentice Jacob, because he is really helpful around the lab, especially when something is heavy. He has been sorting parts for me too. Many boxes of mixed parts. I help him out as well; fixed his OS-8B and his 2215 tektronix scopes this weekend. He wanted to build a plasma gun this wekend. He said that if we draw an arc of high voltage DC of 2-3KV at 1/2A between two carbons (using a choke to keep the arc stable), then place a 1/2 turn of thick wire near the arc so it is between the carbons but not arcing or touching, and then discharge some 1000uF/450V cap into the 1/2 turn, the magnetic field will blow the plasma arc off the carbons and out into the room. I do not know if this is true but I really wanted to fix the power supply instead.
« Reply #1 on: April 05, 2009, 07:05:00 PM »
Can't read yellow
W1ATR
Resident HVAC junkie
« Reply #2 on: April 05, 2009, 07:12:52 PM »
Can't read yellow
Sweet Jebus! It's miserable just trying to look at it. I guess I could highlight it to read it but I'm way to lazy to hold the mouse button and drag over the yellow banana text.
Jared W1ATR
Click for radio pix
WB2YGF
« Reply #3 on: April 05, 2009, 07:15:29 PM »
yOUR cAPS lOCK iS oN  Tongue
ab3al
« Reply #4 on: April 05, 2009, 08:02:44 PM »
cool!!!!!
same color as the front side of my underware
« Reply #5 on: April 05, 2009, 08:23:07 PM »
oh hell. The "preview" function gave a dark background. Ok I fixed it. thanks.
« Reply #6 on: April 05, 2009, 08:30:35 PM »
Pat, you gots the coolest lab by far  Grin
« Reply #7 on: April 05, 2009, 09:45:39 PM »
Thanks way much! I am probably exaggerating at times and I like to tell the tale, but it is the most fun place for me, and with no windows or clocks to bother me, I've pulled all-nighters in the Bunker. I can't say it's the coolest, there have been some really groovy shack pictures posted here. Only complaint is that it's just crowded/full. Many kind people have been very generous to me on numerous occasions. I hope I live long and can retire to spend many pleasant days with electronics and now that most parts/equipment issues are resolved/scheduled; I have lots of excess and it's my turn to be generous.
If I had a BYOB lab party with "door prizes" (doorstop prizes?) would anyone come? HAHA!
I think the point of my story is that I could have caused a very bad accident/capacitor bank explosion, and that even though I was trying to be careful, I still made a dangerous error and neither me nor Jacob noticed it until the experiment was well underway. Reminds me of a line from Philippe Driullet's "Lone Sloan" series of graphic novels -  "Just as the dangerous experiment was reaching its terrifying crescendo..." But I'm preaching to the choir there. At least I can look at it with humor at myself and a smile.
Alot of inspiration comes from many of you on this forum. I see what you guys build and it makes me want to go make somehting too. It's very educational, all the different designs done here.
WB2YGF
« Reply #8 on: April 05, 2009, 10:56:38 PM »
I did a similar thing at work (about 30 years ago).  I had a 3 phase isolation transformer with multiple taps and I set the taps wrong.  It was feeding a bank of around 20 large electrolytics (around 500V rating).  I was running up the 3 phase Variac on the input side of the transformer and BANG!!!.  Hissssss.   One of the caps blew up before I realized the DC bus voltage was WAY too high
N5RLR
Extra With A Side Of Fries
Supremely Lurking
« Reply #9 on: April 06, 2009, 05:55:59 AM »
...If I had a BYOB lab party with "door prizes" (doorstop prizes?) would anyone come? HAHA!
Well, shoot, I just might.  I'm in the same county, y'know. Grin
Michael
Licensed Since 1990  Cheesy
« Reply #10 on: April 06, 2009, 11:43:41 PM »
I'm around most weekends. The lab is in South Dallas 75216.
« Reply #11 on: April 07, 2009, 07:49:03 AM »
I still wanna shop at Patrick's sto ...beefus
RotogenRay
« Reply #12 on: April 24, 2009, 01:38:00 PM »
That was a fun day.
You didn't mention what a gutless wonder that 2215 tektronix was. Just one big board...
BTW I finally got the registration on here to work =)
« Reply #13 on: April 26, 2009, 11:42:26 PM »
I attest to the gutlessness of that scope. Since it was presented as "not working" I first thought someon had stolen a couple boards out of it, slick as a possum with a plate of preserves.
The problem was the focus. the divider resistors change value and there was evidence of previous repairs and board burnage. I replaced each of them with a series set of two 1W resistors, appx. half value each. I bet it never comes back for focus. Welcome to the BBS, or to successful registration anyway.
RotogenRay
« Reply #14 on: May 06, 2009, 03:40:16 PM »
For some reason that scope likes to not work that well. I was trying to look at the audio coming out of my computer (line level- seeing if I was really getting stereo or if I just had a cold solder joint come loose or somethin)
it was loading the audio card down enough to where the speakers cut out entirely, while not reading a thing on the trace with the volume at max.
The mil scope would see the audio and not short the speakers (with the same probe), but its hard to watch the audio waveform when I get so much 60hz on that scope. Its impossible to adjust correctly as well.
« Reply #15 on: May 07, 2009, 01:41:37 AM »
could it be the kind that can ground the probe and you had a 1x probe? it would be unusual for the thing to load a speaker or line down. Maybe has a protection circuit or something shorted?
RotogenRay
« Reply #16 on: May 07, 2009, 04:37:15 PM »
No, I got a nice 10x or 100x probe from Paul. I'll have to look at it again and I'll see what exactly Its doing.
I was just trying to figure out the configuration of the speaker cable- I was able to figure it out easily, though, because the probe shorted out the other speaker on that side of the line:P
« Reply #17 on: May 08, 2009, 12:09:19 AM »
probe is probably bad. They should basically read open, not that i know all probes, but one like that ought to read so high it can't short a speaker lead.
link to the jawsII amp for this power supply:
http://amfone.net/Amforum/index.php?topic=16823.0
Page created in 0.063 seconds with 18 queries.
