March 12, 2026, 02:33:52 AM *
Author Topic: Vacuum Variable  (Read 4383 times)
K9ACT
« on: April 01, 2009, 08:45:44 PM »
I have been plagued with arcing on my 8000 rig and about to give up trying to find a suitable air variable.
Seems like a vacuum variable would be a good option but I am not at all clear on how they work.
A friend said to make sure the one you buy comes with a "puller".  I have spent at least an hour trying to find info on such a device and find nothing.
All the caps I have been looking at have 1/4" shafts and I have been assuming that turning this shaft changes the capacitance like any other cap.
Not so says my friend... you have to pull on the shaft.
I saw one that actually says it has a rotating shaft for cap adjustment.
Could someone clear this up for me.
Here is a link to one that would seem to do the job.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=390012738246
The seller has not responded to email so I would by one elsewhere but does this type require a "puller"?
js
« Reply #1 on: April 01, 2009, 08:52:58 PM »
The puller is the metal cylinder thing on the front that the shaft comes out of. Inside the thing, the shaft is threaded and there is a nut, so that as you turn the shaft, it pulls the 'plates' apart inside the evacuated container. A bellows on the front of the container, insidethe 'puller' as he is calling it, allows this in and out motion.
http://www.altavista.com/image/results?itag=ody&q=vacuum+variable+capacitor&mik=photo&mik=graphic&mip=all&mis=all&miwxh=all
« Reply #2 on: April 01, 2009, 08:53:44 PM »
Jack,
Pat did a good job of describing the puller function.  ( I deleted my duplicate info)
Yes, vac caps are the way to go. I don't use bread slicers here anymore except for low level input circuits.
k7yoo
« Reply #3 on: April 01, 2009, 10:10:46 PM »
If you need a Vacuum variable get in contact with me and I will bring it to the Stoughton fest. How many pf? 300-500?
BTW I have the turns counter & "puller" This is a new one on me!!
Skip
k7yoo@yahoo.com
« Reply #4 on: April 02, 2009, 12:39:04 AM »
it makes me want to cry, now I remembered the day a 2000pF 15KV glass vac var rolled off a desk and splatted on the floor. The untimate loading capacitor.
« Reply #5 on: April 03, 2009, 02:56:28 PM »
Just be careful with "the puller" or shaft....It will be hot with RF!!!
« Reply #6 on: April 03, 2009, 06:38:39 PM »
usually you ground the shaft end unless the whole thing is floating then you need an insulated shaft coupler.
