May 13, 2024, 05:18:31 PM *
Author Topic: Drake R-4A Receiver Test Results  (Read 1605 times)
« on: March 29, 2009, 02:55:21 PM »
Receiver: Drake R-4A
Band    MDSBlocking DR   Two-tone DR
  (20 kHz)  (20 kHz)
80 meters   -137 dBm        121 dB    87 dB
40 meters   -137 dBm        122 dB    88 dB
20 meters   -136 dBm        123 dB    88 dB
AM audio S/N: 45 dB
AM Audio Frequency Response: in dB, referenced to 1 kHz measurement
100 Hz  200 Hz  400 Hz  600 Hz  800 Hz  1 kHz  2 kHz  3 kHz  4 kHz  5 kHz  6 kHz
-33   -21   -3   0   0   0   -4 -10   -23   -32   -40
AM Audio Distortion:
Mod  100 Hz  200 Hz  400 Hz  600 Hz   800 Hz  1 kHz   2 kHz
30%  -  -  14%  7.9%  5.6%  4.0%  2.8%
50%  -  -  16%  11%  8.9%  6.3%  4.0%
70%  -  -  18%  14%  13%  7.9%  5.0%
90%  -  -  20%  16%  14%  10%  5.6%
100%  -  -  20%  16%  14%  10%  5.6%
Notes: AM frequency response was fairly restricted due to the 4.8 kHz maximum i-f bandwidth. AM distortion numbers show the somewhat typical increase at lower audio frequencies - most often caused by the low audio frequencies riding on the AGC line. The audio response rolls off rather quickly on the low end. A frequency response test was run on just the audio output stage which confirmed the tiny audio output transformer to be responsible for the poor low frequency audio performance.
Note that this must have been a 'late' R-4A since the product detector, AM detector, agc and audio preamplifier stages are solid state as in the R-4B. Did not investigate why the AM distortion measurement results were so bad other than to verify all appropriate circuit components were in working order.
Info on the measurement setups and test results on other receivers can be found at:
http://www.w1vd.com/BAreceivertest.html
