R390 won't turn off??!! - - - -
September 29, 2023, 11:20:06 PM *
Author Topic: R390 won't turn off??!! - - - -  (Read 4546 times)
World Wide Radio
« on: March 08, 2009, 09:48:11 AM »
When I go to turn the rig off the light on the Read out stays on. The standby position is working because the receiver goes dead.
Is there a relay?
Anyone experienced this or am I just a lucky person?
SWLR-RNŲ54
Dave KA2J
« Reply #1 on: March 08, 2009, 10:19:51 AM »
Hi Gary.  This is very common.  The little micro switch is hanging up.  Both of my R-390A's do this on occassion.  Turn of the receiver and give the "on/off" knob a lite tap with a soft mallet or piece of wood.  Works everytime for me.  Dave KA2J
Dave KA2J
World Wide Radio
« Reply #2 on: March 08, 2009, 10:42:19 AM »
Got it Dave.  TNX
I shot some De Ox down in there and flipped the switch back and forth two times and it started working.
SWLR-RNŲ54
W2PHL
Phil
« Reply #3 on: March 08, 2009, 05:36:19 PM »
That little micro switch can be a problem. If it continues to act up, drop the front panel and unscrew the switch from the mounting plate. Be careful not to lose the washers/spacers on the assembly. The switch is riveted together, but it can be GENTLY pried enough to shoot some deoxit straight inside. That should fix it for awhile.
Phil
I think therefore AM
« Reply #4 on: March 08, 2009, 10:30:49 PM »
The quick fixes only work for a while. Fair Radio sells replacement switches.
Roy K8VWX
Pr. 4 -1000s Mod Pr. 5868
« Reply #5 on: March 09, 2009, 08:07:45 AM »
        I use a thermister for a soft start in the ac line in all my receivers.I have had no trouble with welding of the micro switch contacts in my 390A's since doing so.I don't remember what  value I used but use one that can handle the current and have the highest ohmic value COLD. You can see this soft start in the pilot light when first turned on.Do not cut the leads on the thermister and place it away from any other components,wires etc. IT DOES GET HOT. 73/Roy
Roy K8VWX
« Reply #6 on: March 09, 2009, 11:18:54 AM »
         Just found the thermistor data I used. Mouser part # 527-CL80  3 Amps @ 47 Ohm cold. It is a good Idea if only to save the inrush current on the tube filaments.
KA2PYQ
« Reply #7 on: March 10, 2009, 07:12:48 PM »
With no power plugged in, work the switch strongly while
blowing (maybe through a straw) on any holes on the switch.
Allow your breath inside to dry a few minutes. Then squirt
some freon through a nozzle or pipe until the switch about
turns into an igloo. Work the switch every now and then as
the switch goes from cold and snowy to wet to warm and dry.
This sometimes cleans things "forever". This works on
potentiometers too, and sometimes flakes dirt or grease off
too.
