Offline
« Reply #1 on: February 04, 2009, 09:11:15 PM » |
Calculate the inductance of the entire coil as if there were no gap, since there will be mutual coupling between the two halves of the coil. If the two halves were widely separated or oriented 90° from each other, so there were no mutual coupling, then you would calculate each one separately and add the inductances together.
In all the years of building transmitters I have rarely, if ever, bothered to use the formulae calculate inductance and then the physical size and number of turns for the coil. I figure out from the charts and tables what the optimum resonating capacitance is, then by trial and error, find how many turns of coil it takes to hit resonance with a coil the appropriate physical size and wire gauge, using that given amount of capacitance.
I always would shoot for a Q of 12, whether pushpull or single ended. Better to be a little on the high side than too low. Class-C finals work best when there is plenty of flywheel effect, and the extra Q gives better harmonic suppression.
I notice the older handbooks recommend a minimum Q of 12, whereas later ones recommend 10.
The reason you can get away with lower Q with pushpull is that the tank circuit gets kicked with a pulse every half rf cycle or twice per cycle, whereas with single ended, it gets a kick only once per rf cycle.
I usually go by the charts in the late 30's through early 50's handbooks, which recommend the resonating capacitance based on plate voltage/plate current.
The total capacitance for a balanced tank circuit, whether pushpull or single ended, is one quarter that of an equivalent single ended circuit, since the capacitance in the balanced tank is split in two, and the two sections are in series. If a single section cap is used in a balanced circuit, think of it as equivalent to taking the single ended capacitance, splitting it in two, and wiring those two sections in series. It will need twice the voltage rating, or slightly more than twice the plate spacing of that of a single ended circuit. If a split stator cap is used, the spacing of each section may be the same.
In fact, the same split stator capacitor may be used in either balanced or unbalanced configuration. For unbalanced, tie the two sections together in parallel, to act as a single capacitor. For balanced, connect to the two stator sections, which connects the two sections in series, with symmetry to ground.
For the same voltage/current ratio, the coil should have twice the number of turns for balanced as for single ended. Twice the number of turns gives 4 times the inductance to resonate with a quarter of the capacitance.
The Q is the same in each case because in the pushpull class C circuit, only one tube functions at a time. Effectively, each tube is tapped down across half the tank coil while the other half remains idle, which means that the entire coil is acting like a step-up transformer, and the tubes each take turns seeing a load impedance that is one quarter of the impedance of the whole coil.
