May 16, 2024, 07:08:12 PM *
Author Topic: SX-99 schematic  (Read 2998 times)
N8IE
Bullies need love too, hug me or I'll punch you!
« on: February 02, 2009, 09:17:29 AM »
Good morning all,
My beloved SX-99 has fell ill.  Cry
I suspect something in the BFO circuit has gone bad, when switched between AM\CW no changes are present and only the strongest of signals are present.
I have noticed for a while, a light "pop" when the radio was first turned on, could be a bad filter cap?
Anyway, I have a copy of the schematic but not one showing voltages, is there such an animal around somewhere?
Thanks es 73
Dan, N8IE
For just $1 a month you can save a Ham from SSB.
Please give to AMfone today, I did!
Remember, Hams don't let Ham's run SSB...
Dan, N8IE
W3FJJ
« Reply #1 on: February 02, 2009, 09:30:01 AM »
Not sure if the voltages are in the owners manual, but
BAMA has the manual you can download.
http://bama.sbc.edu/hallicra.htm
GL  CHuck
N8IE
« Reply #2 on: February 02, 2009, 12:12:52 PM »
GL  CHuck
Thanks Chuck,
I guess this is a case of RTFM.   Embarrassed
I have that manual but failed to take a closer look at page 10, you know the one labeled "Voltage Chart". D'ohhhhhhhh.
Dan, N8IE
Dan, N8IE
N8IE
« Reply #3 on: February 02, 2009, 08:13:44 PM »
Well, a little time with the schematic and the problem is fixed.
A wire between V4 and V5 came loose.
After going over the radio I see that I need to replace a few resistors in there!
One has me stumped though, it appears to read as a 100,000 Ohm and is a carbon type. The schematic only shows two such resistors and both are 1/2 watt, this puppy is at least 1 inch in diameter. It connects at pin 4 of T3 and grounds out on V7.
Dan, N8IE
Dan, N8IE
N8IE
« Reply #4 on: February 03, 2009, 07:16:03 AM »
Thanks to the Hallicrafters group, I now know the component in question is a "black beauty" capacitor.
Wow, amazing how much one learns..... now I have a headache!  Grin
Dan, N8IE
Dan, N8IE
