May 19, 2024, 06:30:27 PM *
Author Topic: Precision Full-wave AM Detector Test Results  (Read 2306 times)
« on: January 19, 2009, 11:36:05 AM »
Had a chance to make measurements on a precision full-wave AM detector yesterday. The detector used for the test was described by K2CU some time ago on AMfone and had been in daily use on the 455 kHz output of my R-390A ... until the changeover to the SoftRock demodulator.
The R-390A was operated in the 16 kHz BW position and MGC mode - same as for the SoftRock testing. Operating in MGC mode provided a convenient means to adjust the input level to the detector. Performance remained essentially the same over a wide range of input levels.
Information on the detector can be found here:
http://www.amwindow.org/tech/htm/alowdisdet.htm
Receiver: R-390A / K2CU Precision Full-wave AM Detector
AM audio S/N: 42 dB
AM Audio Frequency Response: in dB, referenced to 1 kHz measurement
100 Hz  200 Hz  400 Hz  600 Hz  800 Hz  1 kHz  2 kHz  3 kHz  4 kHz  5 kHz  6 kHz
+1   0   0   0   0   0   0 0   0   0   0
AM Audio Distortion:
Mod  100 Hz  200 Hz  400 Hz  600 Hz   800 Hz  1 kHz   2 kHz
30%  1.4%  1.4%  1.4%  1.4%  1.4%  1.6%  1.6%
50%  1.1%  1.4  1.6%  1.6%  1.6%  1.6%  1.6%
70%  1.0  1.1  1.4%  1.4%  1.4%  1.4%  1.4%
90%  1.0  1.4  1.4%  1.6%  1.6%  1.6%  1.8%
100%  1.1  1.6  1.8%  1.8%  1.8%  1.6%  2.2%
« Reply #1 on: January 19, 2009, 11:56:40 AM »
I bet it would be better if you used .1% resistors. BTW the data Rob sent me showed you could go below 30% and still get good results.
« Reply #2 on: January 19, 2009, 01:14:44 PM »
Neglected to mention the setup. R-390A i-f output > broadband amplifier (+17 dB) > K2CU detector > Hafler DH-110 preamplifier.
Good point on the resistors - will be interesting to run the tests again with better matched units. Pretty sure I used 1%ers. Good performance as is, though.
