December 08, 2025, 01:16:16 AM *
Author Topic: Drake 2-C Receiver Test Results  (Read 1702 times)
« on: January 07, 2009, 09:01:37 PM »
Receiver: Drake 2-C
Band    MDSBlocking DR   Two-tone DR
  (20 kHz)  (20 kHz)
80 meters   -138 dBm        112 dB    83 dB
40 meters   -137 dBm        111 dB    82 dB
20 meters   -138 dBm        112 dB    83 dB
AM audio S/N: 41 dB
AM Audio Frequency Response: in dB, referenced to 1 kHz measurement
100 Hz  200 Hz  400 Hz  600 Hz  800 Hz  1 kHz  2 kHz  3 kHz  4 kHz  5 kHz  6 kHz
-22   -11   0   +1   0   0   -4 -10   -14   -34   -42
AM Audio Distortion:
Mod  100 Hz  200 Hz  400 Hz  600 Hz   800 Hz  1 kHz   2 kHz
30%  -  -  7.9%  4.0%  4.0%  4.5%  7.1%
50%  -  -  10%  4.5%  4.0%  4.5%  5.0%
70%  -  -  13%  5.6%  5.0%  5.0%  5.0%
90%  -  -  13%  5.6%  6.3%  6.3%  5.6%
100%  -  -  13%  6.3%  7.1%  7.9%  6.3%
Notes: AM frequency response was fairly restricted due to the 4.8 kHz maximum i-f bandwidth. AM distortion numbers show the somewhat typical increase at lower audio frequencies - most often caused by the low audio frequencies riding on the AGC line. The audio response rolls off quickly on the low end due to undersized coupling capacitors in the AM detector and audio amplifier.
This was Drake's first hybrid tube/transistor receiver. The amplifier, mixer stages and VFO are tubes and all other circuits are solid state.
Info on the measurement setups and test results on other receivers can be found at:
http://www.w1vd.com/BAreceivertest.html
