December 13, 2025, 03:49:04 AM *
Author Topic: Non Inductive Resistors  (Read 4841 times)
K1ETP
« on: January 07, 2009, 08:01:57 PM »
Anyone have a good source for non inductive resistors of the tubular type?  (Please...not Rip-off Sales of Nebraska).  Looking for something about 2K at 50w.  Also, has anyone had any luck using the heat sinked TO-220 style NI's for grid swamping, especially above 40 meters?
Rich
« Reply #1 on: January 07, 2009, 08:12:06 PM »
Rich the TO220 resistors are fine as long as you keep them cool.
They will be less inductive than a 5 inch long resistor.
I think you can also get them in a TO247 for higher dissipation.
try Caddak or Caddok Not sure on the spelling.
K1ETP
« Reply #2 on: January 07, 2009, 08:21:53 PM »
Frank-- I know some have a ceramic/metal back, but what about the C between the metal back and the heat sink.  Would that cause problems on the higher bands?
Rich
« Reply #3 on: January 07, 2009, 08:24:27 PM »
The big Caddocks are only 100W rated at 25C which means a big heat sink and air cooling or oil if your swamping out a lot of power for a big tetrode.
I blew a few up in testing.  http://www.caddock.com/
Big Globars show on Ebay and the oddball values are dirt cheap plus they love abuse.
« Reply #4 on: January 07, 2009, 08:32:47 PM »
Rich,
I have them in a solid state final as feedback resistors and they work to above 6 meters. The ones in my amp bolt directly to the heatsink without an isolator. 50 watt dissipation heatsink will need a good 200 square inches of surface area to keep it cool. As Carl says you need to keep them cool just like a final transistor.
« Reply #5 on: January 07, 2009, 08:39:22 PM »
Lich,
The good thing about swamping resistors is that they are usually mounted under the chassis.  If you use forced air with a chimney, (a good idea even for 813's) it's a natural cooling system... :-)  You can get away with much smaller resistors.
I usually use Globars myself, but they are getting harder to find these days.
I take it you are adding some grid swamping for the higher bands in your new 813 rig?  Have you experienced instability problems or just planning ahead for 10M?
« Reply #6 on: January 07, 2009, 08:45:15 PM »
Tom Vu,
Look at the feedback resistors on the irb amp. Nice and small but they need a good heatsink. Without a heat sink maybe a couple watts.
K1ETP
« Reply #7 on: January 07, 2009, 09:01:17 PM »
Tom--
I'm using 4 X 1200 10w in series parallel right now and they work fine but take up room.  I figure if I increase the R value a tad, I can reduce the drive requirements  and free up some room under the RF deck.  No pressurized forced air, just blowing air across the tube which is fine for 2KV.
« Reply #8 on: January 07, 2009, 09:12:07 PM »
Sounds good, Lich.
Yes, if the final is reasonably stable via neutralization, you might be able to get away with a much higher value, like 4K -7K.  Try it and see by putting those four 1200 ohmers in series = 4.8K.
Frank: Those Irb resistors are pretty small -  would need some air and heatsink too.
Below:  Yaz modeling his new hand-sewn coat. It gets cold out there sailing... :-)    I used an old down filled coat of mine to make it for him.
K1ETP
« Reply #9 on: January 07, 2009, 09:30:58 PM »
Tom--
We don't use no stinkin' neutralization ... just 1.2K of swamping.
« Reply #10 on: January 07, 2009, 09:52:14 PM »
If you are interested in where to find Globar resistors you can go here:
http://www.globar.com/
Contact them and they will tell you where you can get their resistors.  I am not sure, but I would bet you better wear your wallet when you go shopping.
