FYI, the Navigator meter movement was 10ma...
If you can find one, a replacement meter with a 0 to 10ma scale is an Electro - Mechacinal Instrument Co., (EMICO) model #2326. That company is/was in Perkasie, PA. It appears to be what Johnson used with their custom face on it as their OEM part number 22.1403.
A scan of the Johnson scale that will fit in the above meter can be obtained from W2FAL
He is okay in QRZ.
The Navigator scale is not calibrated for the 6146 grid current but the calibration on the meter face is 250ma full scale and you load the 6146 to 115ma.
The manual and meter face (under the 250 scale) reads to peak the grid for max drive.
If you find that meter or one similar, let me know where as I have been
looking for a replacement for my Navigator for years.
By the way, where did you find the EMICO meter you have? I assume your meter fits the panel hole on the Navigator
If you wish to use your 0 to 1ma meter, make a shunt for full scale of 10ma using the
info in the previous post here....(By W2FAL
