May 18, 2024, 08:30:28 PM *
Author Topic: Amperex Tubes, 3-500z  (Read 11134 times)
stansub
« on: December 22, 2008, 12:15:55 AM »
Ameritron in an email said they did not use the Amperex 3-500z, since 2001 because of filament issues?  I have 4 of these tubes that I bought in the 90's and they are fine. I have thought that Amperex was of very good quality? RF parts is selling the Amperex 3-500Z for $320!!!
Anyone have anything technical to say about Amperex?
Thanks,
SS
« Reply #1 on: December 22, 2008, 08:43:03 AM »
I read somewhere carbon plate 3-500Zs were tuffer on the grid structures because they hold heat longer. So keep they fed with plenty of air.
stansub
« Reply #2 on: December 22, 2008, 09:38:01 AM »
What does this have to do with the "Filament Issue" as described in my question?
Thanks,
Stan S.
« Reply #3 on: December 22, 2008, 09:48:51 AM »
The failure mode was sagging elements resulting in a Grid to heater short.
« Reply #4 on: December 22, 2008, 04:16:06 PM »
The grid to fil spacing of a 3-500 is only .004 inch ... about the thickness of a common sheet of paper ... not my favorite tube ...73 ... John
John K5PRO
« Reply #5 on: December 22, 2008, 08:23:44 PM »
I find the Amperex tubes, made by Covimag in France, are fine in my 314R1. They are rugged. I suspect they are more costly than Far East tubes, and Ameritron or whoever has to justify their decision, so they said something about filaments. Haven't heard anything, but i suppose that Covimag could have had a problem for a time. But usually these things go away, once an engineer does his job at the factory, with enough customer complaints.
stansub
« Reply #6 on: December 23, 2008, 09:34:40 PM »
Thanks, finally a report that has real logic.  Thanks,  SS
« Reply #7 on: December 25, 2008, 08:43:52 AM »
John, do you have a timeline on where Amperex built their TX tubes? Going back to Hicksville if possible.
Ive also never had a problem with their 3-500's of any date code and actually try to search them out.
In a SB-220, going to the higher speed fan sold by Harbach keeps them nice and contented.
John K5PRO
« Reply #8 on: December 25, 2008, 03:02:53 PM »
I sure don't have that info. They have been made by Covimag for quite some time, and it is an old Phillips plant.
By the way, I checked yesterday, and noted that at work we switched to using Amperex 3-400Z (yes, they still make these) about a year ago, and have probably used half a dozen with no ill effects. We used to have Eimacs, of course. Never tried Chinese copies. I didn't want to redesign the systems to use 3-500Z unless I was forced to, as the chimney height, the slight change in mu, etc might require some engineering. They are used as a pulse amplifier, inverting. When the tube is conducting, the pulse is off. When they are cutoff, the following stage makes a pulse. The pulse is about 1 mS long, 60 times a second, driving a 4CX3000A cathode follower which then supplies a pair of 4CW250,000B tetrodes their screen voltage (~2 kV pulses).
I was overjoyed to find that Covimag still produce the 3-400Z so that we could continue using this 40 year old designed system (in 5 places) at the particle factory.
Happy New Year to all.
John
K5PRO
in white New Mexico
« Reply #9 on: December 25, 2008, 04:56:12 PM »
Those 3-400s are nice. I have a few here. Too bad they didn't keep the mu the same in the 3-500.
« Reply #10 on: December 26, 2008, 09:53:20 AM »
Interesting that I have a pair of Amperex 3-400Z's and a pair of Sylvania's 3-400Z's for the RCA SB-1K. I have often heard the Amperex's are fairly hearty.
« Reply #11 on: December 26, 2008, 03:42:07 PM »
Was it something to do with the solder melting in the pins that made the filaments intermittent?? Lack of air flow?? OR am I thinking about another RF Tube???
« Reply #12 on: December 26, 2008, 03:44:28 PM »
I had a Heathkit SB1000 and there were issues with the microwave oven POS colling fan that may cause problems with 3-500SZ's
Page created in 0.038 seconds with 18 queries.
