December 03, 2025, 06:48:47 AM *
Author Topic: Arcing Titan 425  (Read 26421 times)
« on: December 11, 2008, 11:49:40 AM »
Hello All,
Is anyone familiar with the Ten Tec Titan 425 linear amplifier??
I have an arcing problem in the tank circuit. As I tune and apporach full rated power the arcing starts.
I'm trying to avoid bypassing the safety interlock and operating with the cover removed to see the source of arcing. But might have to be done to correct the problem.
I have been doing searches on the net for any track record of this problem. Seems that the main concern is the final RF pubes. Very expensive to replace and easily abused from overdriving the grids.
« Reply #1 on: December 11, 2008, 12:17:56 PM »
You'll probably need to do that MOP. I don't know how else you can see the source of the arcing. Have you opened it up and looked for signs of arcing (carbon, zorch marks, etc)?
Hello All,
« Reply #2 on: December 11, 2008, 02:07:07 PM »
YUP Steve
Looks like the path of adventure to take. One hand in the pocket and all that.
It did this before and I opened her up and did not see any signs of the arcing. I'll have to fire it up and look at live conditions this time.
« Reply #3 on: December 11, 2008, 05:58:24 PM »
Chances are pretty good it is in the load air variable.  It is looking into a bad impedance that has changed on you recently.  Same thing happened to me with my AL 1200 into my 160 meter inverted L.  Turned out the radials had enough corrosion at the attach point to cause impedance problems, hence the arc at near full power.
Bet it doesn't do it into a good dummy load does it?
Mike/W8BAC
« Reply #4 on: December 11, 2008, 07:22:50 PM »
Just my 2 cents worth Fred, Don't bypass the safeties. I really think if you take the time with a really bright work light and a magnifier visor you can find the problem. If you can't do that I recommend you put the amp on the bench and find a way to look in through the fan vents. You might find the direction of the arc. Than open her up and investigate.
I know you know the interlocks are for your safety. I honestly think some patients and time spent searching will pay off.
If you use the interlock bypass method Please build a bang stick first to discharge the caps and be really careful please.
« Reply #5 on: December 12, 2008, 09:18:46 AM »
Yea Mike,
I think you can touch 2500vdc one time.
And the arcing is with the amp in a known good dummy load.
I'll have to remember to bring my magnifier visor from work and smoke it over this weekend. It's been convenient to have the Raytheon on 1885 and the linear set-up for 1985.
« Reply #6 on: December 12, 2008, 10:59:17 AM »
Don't know about this particular amp but does it have switched in lumped capacitance in the output side of the tank?  One or more of them may be bad.
« Reply #7 on: December 12, 2008, 11:01:01 AM »
It's not like 2500 volts is going to jump out of the box and get you. You can safely bypass interlocks and remove the appropriate covers to see what you need to see. Stand back and watch for the fireworks. Dimming the lights in the room can help to see the initial area. Then you will know where to look. I'm not recommending sticking your hands in the box, just standing back and observing.
« Reply #8 on: December 12, 2008, 02:34:34 PM »
Ok
I'm making a list and I'm gonna check it twice!!!
Safety, observing the source of arcing and looking into the bandswitch. There are definitely caps switched in for 160M. And they were changed out as a mod from Ten Tec for "a change in tuning while transmitting problem". Not an easy amp. to get into. Tight spots.
I'll get back to you later this weekend
W3NP
« Reply #9 on: December 12, 2008, 04:17:56 PM »
Yea Mike,
Actually, it would be possible for me to touch it a second time but somehow I don't think I would get off so easy if I did.
Been there.....
http://webpages.atlanticbb.net/~w3np/hvsafety.htm
Trust me Fred, it ain't a fun experience!! I would still open up the Titan and do as Steve suggested. Watch it in a dimly lit room for anything amiss. I was just inside my 812H/V70D rig today. Like the carpenter that measures twice and cuts once - I carefully chart my moves and the next position of my hand.
Take care.
---Dave  W3NP
« Reply #10 on: December 12, 2008, 08:06:49 PM »
I had one of the switched caps arcing in the 40 meter bandswitch position.  From there the switch added more fixed caps to the variable so tuning was off on all bands from 40 meters down to 160.  That is how I isolated which cap to replace.
I found it by doing like Steve suggested, then used a 10 watt 100 ohm resistor and made a grounding system out of it.  The HV in my amp is 3600 volts but anything above 1 KV is VERY dangerous.
I learned to work on HV stuff under a master who taught me on a 1 KW system in a BC transmitter back in the 60s.  It probably will be something dirty or shorted like the cap in mine.  Do exercise caution.
« Reply #11 on: December 12, 2008, 08:49:56 PM »
phred, there's your problem.  Cool
« Reply #12 on: December 12, 2008, 09:18:02 PM »
I know the 160 meter fixed padders were a problem for the original amps, I looked into buying one before I decided to go with a homebrew amp instead.  The originals were not capable of handling the current and the loading would shift enough that during long dashes it was evident.  I presume they upgraded those but you might have an earlier model in which the caps have died from "heat prostration".
You should be safe enough observing although it would be a good idea to wear safety glasses in case it ends up sending debris out from the arc.
« Reply #13 on: December 12, 2008, 10:00:14 PM »
Here's a little report on the Titan.
Looking down inside the first section of the bandswitch is arcing within itself.
According to the sheezo, there's a lead coming from the RF final pubes to this section of the bandswitch and there are some transmitting caps that are switched into the tank. I'm thinking that these are the loading caps?
This amp had the mod loading caps installed before I bought it for that drifting problem.
I have noticed that the TUNE (PA Tune) cap is fully unmeshed for tuning at 1985. The loading cap is half meshed. 2000 watts out 70 watts drive.
THanks for the advice and guidance
« Reply #14 on: December 13, 2008, 11:48:53 AM »
fully unmeashed is a problem. You are on the wrong band man
« Reply #15 on: December 13, 2008, 01:10:43 PM »
Actually the Titan has a 160A and 160B selection on the bandswitch.
I'll try for grins what 160A does at 1985. It worked about a month ago on 1985 using 160B. Full P.E.P. no arcing. All tests and set-up are done in a dummy first before going live into the antenna system.
I'm not getting passed the Dummy load.
I'm assuming that "B" is for the upper part of TopBand. The tuning chart seems to indicate that TopBand was broken into segments, prolly for the extra loading required on the lower end 1810-1850?Huh
« Reply #16 on: December 13, 2008, 04:22:03 PM »
It doesn't look too good in the 'ole Titan. The tank circuit is a Pi-L network. The transmitting caps for the Pi side all have cold solder joints. I scanned and posted the scheezo. The bandswitch that is arcing is S1C.
This has a group of transmitting caps with cold solder joints. I can't even begin to think of getting a solder gun or solder pencil in there.
The S1B has a transmitting cap that the phillips screw is completely broken away from the capacitor.
The transmitting caps look like good ones. There is also a pic of some of them on here.
Using the ceramic tubes encourages the sleek design and a very hard device to get into to repair. I'm glad the Raytheon is here. There will be hassles for large QSY's, but I guess that's life.
I'm sure Ten Tec will charge a healthy price for repair/rebuild of the tank circuit. I know I don't want to get into it. Unless I get real desparate for operating.
Thanks for looking. Has anybody worked on TenTec stuff??
« Reply #17 on: December 13, 2008, 04:49:10 PM »
There is only 100 pf difference between 160a and 160b for loading. the 400 pf extra on the plate tune is in for both A and B. No way should you be needing to run the loading fully unmeashed usless there is a vswr problem.
« Reply #18 on: December 13, 2008, 04:58:57 PM »
I bet the tuning knob setting is due to the other problems with the fixed loading caps; until you get those straightened out nothing is going to behave normally with the output tank.  It is also quite possible the 400 pf unit was damaged when problems occurred on the output side of the tank.
Ten Tec is supposed to be pretty good about service so I would get in contact and get a quote.  If there are cold solder joints it sounds like that happened during a "field upgrade" of the fixed capacitors.
The only work I have done on Ten Tec is repairing the PTO's in my Century 21.  Hopefully if Ten Tec pricing is not reasonable you can find someone close by to help you out.
« Reply #19 on: December 13, 2008, 05:16:43 PM »
Phred,
I'm surprised by how ten tec has those padder wires arranged - that is at least 3 zorches waiting to happen. ( or that has happened)
if you trust a one handed brain damaged cancer patient to repair it, ship it here and I will look at it for nothing. It looks rather straightforward. if I don't think I can fix it, I'll do nothing to it and  you can arrange to have it shipped to Ten Tec from here.
note: I know thats a high dollar item, NP if you would rather have someone else do it.
« Reply #20 on: December 13, 2008, 05:28:24 PM »
Ususally the design impedance for the juncture of the L coil/load cap to the Pi coil is 300 ohms.  If the amplifier is seeing something other than 50 ohms at the antenna relay, then this is reflecting back to S1C which is where the problem is.
Are you sure of the contacts in the antenna relay?  What about the wire connecting the L coil to the antenna relay?  The cold solder joints could be the result of high circulating current which heated the solder.  From the picture it appears one of the caps arced which may have been the cause of the problem, then others.
I would bet you had some sort of antenna trouble and when it arced the first time, it did the deed to the rest of the circuit.  I suggest you do your own repairs.  The expensive thing will be the doorknobs.  Those things are in the 25 dollar range, and that is each.  Just think of it as a challenge and take your time being sure of all mechanical and solder joints.  High power presents its own problems at connections.
When I had to replace the two doorknobs in mine, I bought from Ameritron.  Turned out Surplus Sales of Nebraska had them cheaper than Ameritron.  You might check there if you do your own repairs.
« Reply #21 on: December 13, 2008, 06:00:26 PM »
Maybe an off the wall idea here, but did you try to contact Ten-Tec Phred? They have a Tech Support group that is supposed to be second to none. What the hell give them a try and ask them where to look. I've heard they have sent parts without an order.
« Reply #22 on: December 13, 2008, 10:32:44 PM »
I hate to throw the white flag up on this, but it requires a lot of disassembly before even getting to the problem area. Placement of wires and the proper doorknobs might get frustrating. I would get pretty hot if I went through all of that mechanical rig-ama-role and the dam thing  is worse off, than when I began.
I'll check with TenTec. Like Mike(y) says and, maybe one other, TenTec is suposed to have quite a team in the repair shop and they will give it the final smoke test before leaving the shop. It's a pretty strong amp and not afraid to put out the P.E.P. Dead carrier was a little over 2000 watts and I was not driving the tubes very hard, about 70 ma. I would hate to pop expensive ceramic tubes like those with my hit and miss approach. They are supposed to last a very long time.
I'll give an update what TenTec says they'll do for me. Thanks for the great input, though. If it was more of a traditional design and not using ceramic pubes, I would jump in there with a Weller D650........300watt soldering iron and do my thang
Phred
« Reply #23 on: December 13, 2008, 10:47:16 PM »
Phred,
Knowing when not to tackle something is a very wise; too bad it is a lesson lost on many politicians and business leaders.  You definitely don't want to blow up anything expensive (or irreplaceable such as the operator!)  I have toured Ten Tec a couple of times while down in the Smokies and it appears to be a very friendly group.
A good trick for checking the output network after working on an amp and before putting in the expensive tubes is to use one of the generic antenna analyzers like the MFJ 259 series to check your work.  Since the output network is an impedance transformer it works equally well in both directions.  So calculate the normal operating load for the amplifier tubes and then connect from the anode connector a resistor (to ground) of the value calculated.  Of course all of the testing is done with the power disconnected.  Connect the analyzer to the amplifier output and either bypass, manually close, or supply power to the T/R relay only (whichever method is easiest).  If everything is as it should be the analyzer will indicate a match with the bandswitch, tune, and load controls in their proper position.  This won't catch parts that will arc over at normal operating power but it will catch wiring, soldering, grounding, or component value errors before you turn dollars into smoke.
The 425 is a nice amp and I hope yours is back to making RF soon!
« Reply #24 on: December 14, 2008, 12:24:07 AM »
Try loading iy up on 75 and 40 and see if it plays. The 400pf cap open you might be fully unmeashed to get a dip on the second harmonic. The caps still look ok  so maybe the band switch is bad.
I agree with Derb those 3 cap wires look pretty close.
Page created in 0.06 seconds with 17 queries.
