December 03, 2025, 02:32:24 AM *
Author Topic: Crappy audio traced to crappy DVD player of all things  (Read 5229 times)
« on: December 04, 2008, 01:04:43 PM »
Checked into a local 75M QSO this morning just  before going to work and got a crappy audio report -- humm and dist... audio.
On a hunch, I unplugged a Phillips DVD player ($29.99 special) I have had other probs.. with and the problem went away.  Steve QIX made a comment  about an incompatibility issue with some foreign mfg stuff.  Anyway -- how's that for an interesting problem / solution?
Al
« Reply #1 on: December 04, 2008, 04:26:37 PM »
Oh, so you were the guy playing music with hum on it on 75 meters?  Tongue
W2JBL
« Reply #2 on: December 11, 2008, 12:28:17 AM »
   i had similar problems here at a recently established station in Brewster NY. i traced the problem to a Memorex VCR/DVD machine plugged into the same power strip as my audio processing junk. seems the switching power supply in the DVD machine was spraying all sorts of noise back into the line and my audio gear did not like it. best way to play music on boatanchors is from a turntable playing vynl records to a tube phono preamp...
« Reply #3 on: December 11, 2008, 06:11:55 AM »
Ok, I'll bite  Wink
I'm not sure I understand what, or how, whatever happened - happened.
Was this thing in any way hooked up to the transmitter and/or audio system?
Perhaps there was an odd-ball ground loop or something like that.  What are the particulars?  How was everything connected?
VO1GXG
« Reply #4 on: December 11, 2008, 02:50:28 PM »
Had a problem with a LCD TV powersupply. Took the psu from the tv and wrapped it in lead tape, solved that problem
« Reply #5 on: December 11, 2008, 04:14:53 PM »
I hope the PSU doesn't overheat from the tape job......
« Reply #6 on: December 12, 2008, 05:22:08 PM »
I had my audio system interconnected to my computer to play internet music.  The DSL modem put a lot of crap into the audio system not to mention polluted the air in my living space. Putting its switching power supply into a grounded box eliminated the problem.
« Reply #7 on: December 14, 2008, 08:06:30 PM »
NO
« Reply #8 on: December 14, 2008, 08:13:38 PM »
Ok, I'll bite  Wink
Beats the heck out of me Steve.  First time I noticed a problem with this unit was a motor sounding like noise on not only 75 but on the AM broadcast band.  I found the problem by going around the house with an AM broadcast RX and used the loop ant in it to triangulate on the problem.
 The second time I noticed a problem was a hum on my monitor / receiver system while transmitting although no one else heard it  (unplugging the DVD player cured the problem in every case).
The final problem was that gawd-awful sound imposed on my audio chain.  In every case the unit was turned off, just plugged in.  AGAIN, unplugging it removes all of these problems.  Go figger.
Al
Page created in 0.046 seconds with 15 queries.
