So this afternoon I am out in the barn running some glued up panels through my drum sander and I hear a pop and then see smoke coming from the motor on my dust collector. I shut everything down and find the motor run capacitor emitting smoke and a most unpleasant odor. The capacitor was made by Yuchang, wonder what country that came from
I found a suitable substitute in the junk box (an older U.S. made motor run capacitor same value but much larger) that brought my Delta dust collector back to life and I finished running the panels. I will need to find a modern replacement since the temporary replacement is far too large to fit into the space vacated by the original part.
At least the part is easy to get to unlike many transmitter parts and it did last about 8 years so I guess the quality wasn't too bad. Of course I wasn't planning on stopping for close to an hour just to get the dust collector running again because the drum sander would quickly load up with sawdust without the collector. Hopefully final sanding and staining will not involve any additional drama tonight.
